Audirvana Studio will only play 4-5 tracks from my Tidal Playlist then stops, and gives me an error, “Error starting playback device”!
I am on the Trial version, but this does not look good, I have about 1000 songs in my Tidal playlist, and enjoy playing them randomly. Will Audirvana Studio not do this?
I have tried increasing my buffer to default 29 Mb down to Zero nothing works!!
Thanks!!
Here is my debug Info!!!
Audirvana Studio 1.11.0 (11100)
macOS 12.2.1 with 32GB physical RAM
Connected account of : Graham Logan
Globally: ON
Per track: OFF
Effects plugins ACTIVE in realtime mode with legacy macOS API
No plugin active
SoX with 2x upsampling
Bandwidth at 0dB = 99.5%
Phase = 60%
Sync list: 0 folders
Library database path: /Users/grahamlogan/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 59098
Preferred device: HEGEL H190D45076 Model UID:Hegel H190D45076 UID:uuid:200f71e8-1dd2-11b2-9f5c-5dc17015a6a3
UPnP device at http://192.168.2.48:38400/description.xml
ID 0x0 H190D45076
Manufacturer: Hegel
Model Name:
Model UID: Hegel H190D45076
UID: uuid:200f71e8-1dd2-11b2-9f5c-5dc17015a6a3
Volume control: No
Avoid RAW PCM streams: Yes
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:04:00.000
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL SHUFFLE REPEAT_ONE REPEAT_TRACK REPEAT_ALL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string ABS_COUNT TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 QPlay:2 urn:schemas-upnp-org:device:MediaRenderer:1 H190D45076 Hegel http://www.hegel.com H190 H190 1.0 http://www.hegel.com uuid:200f71e8-1dd2-11b2-9f5c-5dc17015a6a3 http://192.168.2.48 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay.xml /QPlay /QPlay/eventSub http://192.168.2.48:38400UPnP devices found : 1
Device #0: ID 0x0 H190D45076 UID: uuid:200f71e8-1dd2-11b2-9f5c-5dc17015a6a3 Location: http://192.168.2.48:38400/description.xml
Max. memory for audio buffers: 256MB
Local devices found : 4
Device #0: ID 0x43 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:15 UID: AppleHDAEngineOutput:1F,3,0,1,1:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x38 Lightning Audio Adapter Output Manufacturer: Anker Innovations Ltd. Model UID: USB Audio Interface:291A:8178 UID: AppleUSBAudioEngine:Anker Innovations Ltd.:Anker Lightning Audio Adapter:A8178W19503.00289:3 Model Name: Anker Innovations Ltd. Lightning Audio Adapter Output
Device #2: ID 0x2c MMAudio Device Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID UID: MMAudioDevice Model Name: MMAudio Device contributors MMAudio Device
Device #3: ID 0x32 MMAudio Device (UI Sounds) Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID_UISounds UID: MMAudioDevice_UISounds Model Name: MMAudio Device contributors MMAudio Device (UI Sounds)
