My Audirvana Studio software wont load. I am getting the following message:
Error: UnhandledException: The parameter is incorrect
Im using a PCwith Windows 10 … the software worked perfectly prior!
Any advice please!
Regards
Jonathan
Any advice please!
Regards
Jonathan
Heya,
Antoine will be back in the office tomorrow daytime (in Paris).
But you could try a reinstall of Audirvana Studio. You can download the latest version if you log into your account on www.audirvana.com
Click on the Download button. In the next screen it should start downloading the setup file automatically. You can also choose a version there (Mac or Windows).
Hello @TriodeFan ,
Can you send us your audirvana.dmp and audirvana.log file at support@audirvana.com?
to show AppData folder:
