Hello !
My environment : MacBook Pro 16" 2019, MacOs 12.2.1, xDuoo XD-05 Basic, Audirvana Studio.
While playing any DSD from 64 to 256 no sound. Audirvana and xduoo display DSD mode.
Hello !
Hello @bashmod,
If you go in your audio output settings, do you have DSD over PCM enabled?
Did you try both DoP modes?
Yes, I have DSD over PCM1.1. And tried DSD over PCM 1.0.
If your DAC has a volume control, you may need to ensure it is set at 100% during DSD playback to prevent its USB interface from damaging the DSD signal.
I tried 100% DAC volume control there is no effect. Audirvana volume control set to 100% and software volume control disabled.
Audirvana Studio 1.11.0 (11100)
macOS 12.2.1 with 16GB physical RAM
Connected account of : Oleg Bash
AUTO: /Users/a16697764/Documents/Zubrev/music
Library database path: /Users/a16697764/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52454
XDUOO USB AUDIO 2.0 XDUOO USB AUDIO 2.0
Model UID:xDuoo USB Audio 2.0:152A:8807
UID:AppleUSBAudioEngine:xDuoo USB Audio 2.0:xDuoo USB Audio 2.0:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x74 xDuoo USB Audio 2.0
Manufacturer: xDuoo USB Audio 2.0
Model Name: xDuoo USB Audio 2.0
Model UID: xDuoo USB Audio 2.0:152A:8807
UID: AppleUSBAudioEngine:xDuoo USB Audio 2.0:xDuoo USB Audio 2.0:14100000:1
Audio buffer frame size : 116 to 4096 frames
Stream ID 0x75 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 3
Device #0: ID 0x74 xDuoo USB Audio 2.0 Manufacturer: xDuoo USB Audio 2.0 Model UID: xDuoo USB Audio 2.0:152A:8807 UID: AppleUSBAudioEngine:xDuoo USB Audio 2.0:xDuoo USB Audio 2.0:14100000:1 Model Name: xDuoo USB Audio 2.0
Device #1: ID 0x54 Динамики MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Динамики MacBook Pro
Device #2: ID 0x2e ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001 Model Name: zoom.us ZoomAudioDevice
Can you reduce the maximum RAM that Audirvāna Studio can use to 4000MB? You can do this in the Loading/Decoding section.
Done. No sound yet.
If you try to play to it using Music instead, does it works?
Do you mean when play any music ? While playing from Tidal or DSD through mode: “None: convert to PCM” sound is good. No issue.
I mean iTunes/Music app of MacOS (I know it’s confusing sometimes )
Apple Music - sound is good. Under Hi-Res mode.
Can you remove the limitation and the mute during sample rate change so you will have the by default settings of Audirvāna Studio?
Okay, now we will try one step at a time. Can you first try to deactivate the Large Core I/O buffer?
If it still doesn’t work, deactivate Exclusive access and Integer mode and try again.
No sound yet.
