Audirvana is stuttering when playing DSD256 tracks, I’m USB connected to a desktop DAC that supports up to DSD512 (I have tested this successfully with other sources), what could I change in the program to stop the stuttering?
Thanks!
Thanks!
Try lowering the memory buffer to 1024mb around
Wow, I didn’t know about the DAC settings on this program itself, thanks.
I actually fixed it by increasing the memory buffer.
This solved the issue, THANKS!
