Please repair Audirvana’s UPnP behavior.
It is simply not working. I have to restart Roipieee and Optical Rendu each and every time i want to use Audirvana Studio. Trying to stream HRA is a game of luck, after one year of Studio development.
I will not extend my subscription, if these basics aren’t resolved. I will check back in September.
This has completely soured my Audirvana experience.
JRiver works flawless. So it is an Audirvana problem.
Hello @Gustav1,
What is the UPnP issue you have? You do not see your device when you want to us them in Audirvāna Studio in UPnP? Are you using the latest firmware version for your Optical Rendu?
Hello Antoine
I use the latest versions of Optical Rendu and Roipieee. I keep them updated.
Like I said, Audirvana will not start playing files, if I don’t restart these devices.
Audirvana won’t stream from HRA. Sometimes it works, most of the time Not.
I read something like: Could not initialize playback etc…
This behavior is common knowledge in the community. It should not surprise you.
I will resubscribe if and when Audirvana works. I am not a beta tester for basic functions.
Actually it is not common that streaming from HRA do not work or I should have hundreds of request about it each day.
And for the UPnP issue you have that has been ongoing for a long time, have you ever sent your debug info on the forum for example so I can check it out? UPnP is really complex in a lot of ways and in the case of Audirvāna, it rely on the UPnP implementation of your device.
As I said, I try Audirvana again later this year.
Some say, Audirvana is a messy bug ridden…
Right now, I am out.
If it works, I resubscribe.
JRiver works all the time.
I get random disconnects from the Optical Rendu (Signature Rendu SE optical) with every version of Studio. And yes, I have provided the debug info-time for Damien and company to address this issue.
Continuing the discussion from Audirvana UPnP behavior:
After a long time of having no problems running AVS through microRendu by DLNA, it is now shutting down in the middle of playback. The only solution is a complete reboot of microRendu and AVS. Here’s the debug info. The section under ‘Current device MediaInfo’ is what was playing the last time it stopped.
Any advice please??
Audirvana Studio 1.13.0 (11300)
macOS Version 12.4 (Build 21F79) with 16GB physical RAM
Connected account of : Greg Burgess
SW volume control: ON
Sync list: 3 folders
AUTO: /Volumes/4TB SSD/Music/Digital Audio
AUTO: /Volumes/4TB SSD/Music/DSD Audio
AUTO: /Volumes/4TB SSD/Music/Tracks
Library database path: /Users/gburgess/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 61224
Preferred device: JF LIGHT INDUSTRIES MRENDU-027E48-UPNP/AV Model UID:JF Light Industries mrendu-027E48-UPnP/AV UID:uuid:c3707f3f-1aef-f57a-ea40-d063b4027e48
UPnP device at http://10.1.1.54:49152/uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/description.xml
ID 0x0 mrendu-027E48-UPnP/AV
Manufacturer: JF Light Industries
Model Name:
Model UID: JF Light Industries mrendu-027E48-UPnP/AV
UID: uuid:c3707f3f-1aef-f57a-ea40-d063b4027e48
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::application/flac:
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
34 virtual formats:
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 44.1kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 88.2kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 176.4kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 352.8kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 48kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 96kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 192kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 384kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 32 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz finite length
0 physical formats
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://10.1.1.121:49152/audirvana/audio_0.wav
CurrentURIMetadata:
dc:titleHave You Ever Loved a Woman (Live)</dc:title>
dc:creatorEric Clapton</dc:creator>
upnp:artistEric Clapton</upnp:artist>
upnp:genreRock</upnp:genre>
upnp:albumArtURIhttp://10.1.1.121:49152/audirvana/artwork_0_0.jpg</upnp:albumArtURI>
upnp:album24 Nights (Live)</upnp:album>
upnp:originalTrackNumber6</upnp:originalTrackNumber>
nextURI: http://10.1.1.121:49152/audirvana/audio_1.wav
nextURIMetadata:
dc:titleWorried Life Blues (Live)</dc:title>
dc:creatorEric Clapton & B.B. King</dc:creator>
upnp:artistEric Clapton & B.B. King</upnp:artist>
upnp:albumArtURIhttp://10.1.1.121:49152/audirvana/artwork_1_1.jpg</upnp:albumArtURI>
upnp:originalTrackNumber7</upnp:originalTrackNumber>
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 mrendu-027E48-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.5.12 libupnpp 0.21.0 image/png 64 64 32 /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/icon.png /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/presentation.html uuid:c3707f3f-1aef-f57a-ea40-d063b4027e48 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/evt-urn-schemas-upnp-org-service-ConnectionManager-1UPnP devices found : 1
Device #0: ID 0x0 mrendu-027E48-UPnP/AV UID: uuid:c3707f3f-1aef-f57a-ea40-d063b4027e48 Location: http://10.1.1.54:49152/uuid-c3707f3f-1aef-f57a-ea40-d063b4027e48/description.xml
Max. memory for audio buffers: 12154MB
Device #0: ID 0x55 Studio Display Speakers Manufacturer: Apple Inc. Model UID: Studio Display Audio Control:05AC:1114 UID: AppleUSBAudioEngine:Apple Inc.:Studio Display:00008030-001511292ED8802E:8,9 Model Name: Apple Inc. Studio Display Speakers
Device #1: ID 0x4a Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
Has been sent to you various times since 7/2021. At least twice, as you asked for it.
The problem lies in Audirvana, because all other UPnP software work with Optical Rendu and with Roipieee. ONLY Audirvana does not work properly. You will lose many costumers if you choose to let your head stuck in the sand and ignore that long term (already in 3.5) problem.
I agree with you, It an old UPnP problem never solve
It’s the reason that I don’t registered yet.
