Audirvana will not start after install. Here is a fault cut form Event Viewer:
Programnavn med feil: Audirvana.exe, versjon: 3.5.40.2040, tidsangivelse: 0x5f50bcf5
Modulnavn med feil: KERNELBASE.dll, versjon: 10.0.19041.488, tidsangivelse: 0x5b4a3325
Unntakskode: 0xe0434352
Feilforskyvning: 0x0000000000023e49
Feil prosess-ID: 0x6e0
Feil starttid for program: 0x01d68b7e31aa7e2b
Feil programbane: C:\Program Files\WindowsApps\Audirvana.Audirvana-4118-9484-d80dbb7827cd_3.5.40.0_x64__fec4hfhj3emgj\Audirvana\Audirvana.exe
Feil modulbane: C:\WINDOWS\System32\KERNELBASE.dll
Rapport-ID: 81e7b514-e574-4b45-a535-4706848b2297
Fullstendig navn på feilpakke: Audirvana.Audirvana-4118-9484-d80dbb7827cd_3.5.40.0_x64__fec4hfhj3emgj
Relativ program-ID for feilpakke: App
----- and----
Application: Audirvana.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
at Audirvana.App.OnStartup(System.Windows.StartupEventArgs)
at System.Windows.Application.<.ctor>b__1_0(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at Audirvana.App.Main()
