Hello. I use Audirvana with a dedicated Mac mini and a little monitor with 1024 X 768 resolution. I used Audirvana Plus without any problem but, unfortunately, the new Audirvana window is too large and cannot be resized to fit my monitor. Is there a way to solve this problem? Thank you.
True, the application needs almost the full screen of my 2015 15" retina MBP at default scaling (“looks like 1440x900”) to work well. Nevertheless, the difference to native 1024x768 isn’t that big - this could be fixed.
As a workaround, there are the remotes…
