Hi,
received today the project stream box s2 ultra. it was a breeze to connect the box to my network.
Audirvana shows under UPnP the stream box. Selected the box and music playing works.SQ is superb.
But…audirvana does not use any of my audio-unit plugins anymore. They simply do not work this way.
Checked both on my MacBook Pro and iMac.
Reconnected the old way through usb to my DAC plugins work again. mmmmh
I’m on Audirvana.v3.2.14. Checked a few older versions…in all tested versions no au-plugins are working with
UPnP the/stream box.
Any help? Any ideas?
thanks
