I’m trying to use Audirvana Studio on the Z10 Pro and it doesn’t work, it opens but when I try to play it closes, Roon works fine but I wanted to try Audirvana, has anyone tried it?
Excuse the English, I used Google.
Are you running Kodi on it?
Hello thanks for answering… well no, I don’t have kodi installed…
You‘ll need something to provide UPnP capability. Check with the manufacturer what they recommend. In alternative look for third party Android apps that provide this functionality.
Well no, I only have the Z10 PRO via hdmi, I’ll try the analog one, thanks.
I have tried other outputs, analog and digital and it doesn’t work, the program opens on the Z10 PRO but when trying to play it the player opens and closes immediately, it seems some kind of incompatibility, it’s very strange because Roon works without a problem, it’s a sorry it doesn’t work.
Are you using a Mac or Windows computer?
Windows 11…on the PC I open Audirvana and it links with Audirvana of the Z10 PRO, so far there is no problem, I can browse and select what I want to listen to from both Tidal and Qobuz, but it does not play, the Z10 player opens and then it closes.
Ok I’ll do that, thanks for the help.
This is the debugging from Windows 11, then I’ll try from the Z10 PRO.
Audirvana Studio 1.11.0 (11100)
Windows 11 (22000) with 8GB physical RAM
Connected account of : Carlos Madrid
Per track: OFF
Sync list: 0 folders
Library database path: C:\Users\energ\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.1.125 on port 50277
Preferred device: Plutinosoft LLC Z10 Pro(Living room) Model UID:Plutinosoft LLC Z10 Pro(Living room) UID:uuid:800a8056c0d6-dmr
UPnP device at http://192.168.1.15:1302/description.xml
Manufacturer: Plutinosoft LLC
Model Name:
Model UID: Plutinosoft LLC Z10 Pro(Living room)
UID: uuid:800a8056c0d6-dmr
2 available sample rates up to 48000Hz
Volume control: No
Avoid RAW PCM streams: Yes
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO
http-get::video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_SP_G726
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL
http-get::image/jpeg:DLNA.ORG_PN=JPEG_MED
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO
http-get::image/jpeg:DLNA.ORG_PN=JPEG_SM
http-get::video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMDRM_WMABASE
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVSPLL_BASE
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC_XAC3
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMDRM_WMVSPLL_BASE
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_BASE
http-get::video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L5_SO_G726
http-get::image/jpeg:DLNA.ORG_PN=JPEG_LRG
http-get::video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL_XAC3
http-get::video/mpeg:DLNA.ORG_PN=MPEG1
http-get::image/jpeg:DLNA.ORG_PN=JPEG_TN
http-get::video/x-ms-asf:DLNA.ORG_PN=MPEG4_P2_ASF_ASP_L4_SO_G726
http-get::video/x-ms-wmv:DLNA.ORG_PN=WMVSPML_MP3
http-get::video/x-ms-wmv:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: dB
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI: http://192.168.1.125:49152/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL SHUFFLE SHUFFLE_NOREPEAT RecordStorageMedium string NOT_IMPLEMENTED LastChange string RelativeTimePosition string CurrentTrackURI string CurrentTrackDuration string CurrentRecordQualityMode string NOT_IMPLEMENTED CurrentMediaDuration string AbsoluteCounterPosition i4 RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 AVTransportURI string TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT CurrentTrackMetaData string NextAVTransportURI string PossibleRecordQualityModes string NOT_IMPLEMENTED CurrentTrack ui4 0 65535 1 AbsoluteTimePosition string NextAVTransportURIMetaData string PlaybackStorageMedium string NONE UNKNOWN CD-DA HDD NETWORK CurrentTransportActions string RecordMediumWriteStatus string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NONE UNKNOWN CD-DA HDD NETWORK AVTransportURIMetaData string NumberOfTracks ui4 0 65535 A_ARG_TYPE_SeekMode string REL_TIME TRACK_NR A_ARG_TYPE_SeekTarget string PossibleRecordStorageMedia string NOT_IMPLEMENTED TransportStatus string OK ERROR_OCCURRED TransportPlaySpeed string 1Current device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 / Z10 Pro(Living room) Plutinosoft LLC http://www.plutinosoft.com Plutinosoft AV Media Renderer Device AV Renderer Device http://www.plutinosoft.com/platinum uuid:800a8056c0d6-dmr DMR-1.50 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/800a8056c0d6-dmr/scpd.xml /AVTransport/800a8056c0d6-dmr/control.xml /AVTransport/800a8056c0d6-dmr/event.xml urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/800a8056c0d6-dmr/scpd.xml /ConnectionManager/800a8056c0d6-dmr/control.xml /ConnectionManager/800a8056c0d6-dmr/event.xml urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/800a8056c0d6-dmr/scpd.xml /RenderingControl/800a8056c0d6-dmr/control.xml /RenderingControl/800a8056c0d6-dmr/event.xmlUPnP devices found : 3
Device #058GX800_Series UID: uuid:4D454930-0100-1000-8001-80C755F6D4C2 Location: http://192.168.1.129:55000/dmr/ddd.xml
Device #1Z10 Pro(Living room) UID: uuid:800a8056c0d6-dmr Location: http://192.168.1.15:1302/description.xml
Device #2VSX-930 B114EE UID: uuid:5F9EC1B3-ED59-79BB-4530-745e1cb114ee Location: http://192.168.1.63:8080/description.xml
Max. memory for audio buffers: 1268MB
Local Audio Engine: WASAPI
Device #0: Altavoces (Realtek(R) Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{175a27c0-49a3-4ed7-8cf7-190f66a4dccf}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Altavoces (Realtek(R) Audio)
Per track: OFF
Listening on 192.168.1.125 on port 56297
Currently playing to UPnP device at 24 bits 48kHz
UPnP device at http://192.168.1.15:1818/description.xml
Model Name:
Volume control: No
Avoid RAW PCM streams: No
DLNA 1.5: Yes
Gapless playback: No
Volume Control: dB
NrTracks: 0
CurrentURI: http://192.168.1.125:49152/audirvana/audio_6.pcm
CurrentURIMetadata:
dc:titleLady Love Me (One More Time) [2015 GH Version]</dc:title>
dc:creatorGeorge Benson</dc:creator>
upnp:artistGeorge Benson</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumArtURIhttp://resources.tidal.com/images/154b4bc6/3b82/4006/9077/0e815e4492ce/640x640.jpg</upnp:albumArtURI>
upnp:albumThe Ultimate Collection</upnp:album>
nextURI:
nextURIMetadata:
PlayMedium: NONE
Device #1VSX-930 B114EE UID: uuid:5F9EC1B3-ED59-79BB-4530-745e1cb114ee Location: http://192.168.1.63:8080/description.xml
Device #2Z10 Pro(Living room) UID: uuid:800a8056c0d6-dmr Location: http://192.168.1.15:1818/description.xml
Can you go in your device output settings in Audirvāna Studio and disable the option to send RAW PCM stream?
I seem to remember that I already tried it without result but I will try it again and I will tell you.
I have also contacted Zidoo but the response received was a simple “It may be a compatibility problem”…
Can you try to play to your TV - 58GX800_Series to check if you also have this behavior?
On the 58GX800 plays everything fine except the unsupported ones (192Khz…MQA…) logically.
