16-44.1升频输出:
macOS 10.11.6 with 8192MB RAM
Sync list: 10 folders
AUTO: /Volumes/Data/音乐文件/圣经推荐(208张专辑)/22张天价古典[24K金碟]+5张古典CD(30张CD)
AUTO: /Volumes/Data/音乐文件/圣经推荐(208张专辑)/刘汉盛榜单100碟(104CD)/刘汉盛榜单专测人声(14CD)
AUTO: /Volumes/Data/音乐文件/圣经推荐(208张专辑)/刘汉盛榜单100碟(104CD)/刘汉盛榜单人声与器材(11CD)
AUTO: /Volumes/Data/音乐文件/圣经推荐(208张专辑)/刘汉盛榜单100碟(104CD)/刘汉盛榜单其它测试(66CD)
AUTO: /Volumes/Data/音乐文件/圣经推荐(208张专辑)/刘汉盛榜单100碟(104CD)/刘汉盛榜单大中小提琴(13CD)
AUTO: /Volumes/Data/音乐文件/圣经推荐(208张专辑)/圣经推荐专辑(75CD)
AUTO: /Volumes/Data/音乐文件/红绿精选(15CD)
AUTO: /Volumes/Data/音乐文件/高轨音乐(8CD)
AUTO: /Users/ssxbb9855/Music/未合并SACD专辑2019(共计专辑31张,图片显示30张)
AUTO: /Volumes/SSXONE/SACD专辑(文件夹333,图片显示346,共计专辑364)
Library database path: /Users/ssxbb9855/Music/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 256MB
YULONG Audio 384K DSD DAC*
Model UID:YULONG Audio 384K DSD DAC*:16D0:07EC
UID:AppleUSBAudioEngine:YULONG Audio:YULONG Audio 384K DSD DAC*:413-001:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 352.8kHz
Active Sample Rate: 352.8kHz
Hog Mode is on
ID 0x3e YULONG Audio 384K DSD DAC* Manufacturer:YULONG Audio
Model UID:YULONG Audio 384K DSD DAC*:16D0:07EC UID:AppleUSBAudioEngine:YULONG Audio:YULONG Audio 384K DSD DAC*:413-001:2
Audio buffer frame size : 106 to 4096 frames
Stream ID 0x3f 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 6
Device #0: ID 0x5a 内建输出 Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x61 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:33 UID: AppleHDAEngineOutputDP:1B,3,1,2:0:{D94D-7402-01010101}
Device #2: ID 0x37 TE7022 Audio w/ SPDIF Manufacturer: GFEC ASSP Model UID: TE7022 Audio w/ SPDIF:1852:7022 UID: AppleUSBAudioEngine:GFEC ASSP:DigiHug USB Audio:fd120000:2,3
Device #3: ID 0x3e YULONG Audio 384K DSD DAC* Manufacturer: YULONG Audio Model UID: YULONG Audio 384K DSD DAC*:16D0:07EC UID: AppleUSBAudioEngine:YULONG Audio:YULONG Audio 384K DSD DAC*:413-001:2
Device #4: ID 0x26 1: Hilo-TB Manufacturer: Lynx Studio Technology, Inc. Model UID: LynxAudioDevice:1: Hilo-TB in Thunderbolt@194,0,0 UID: LynxAudioEngine:A1-D3114:0
Device #5: ID 0x4c Splashtop Remote Sound Manufacturer: Splashtop Inc. Model UID: com_splashtop_driver_RemoteSound:SplashtopRemoteSoundDevice UID: SplashtopRemoteSoundEngine:0
UPnP devices found : 1
Device #0: ID 0x0 客厅的小米盒子 UID: uuid:F7CA5454-3F48-4390-8009-403e48e04b1a Location: http://192.168.2.121:49152/description.xml
