Antoine 様
ありがとうございます。
次の通りよろしくお願い致します。
macOS 10.12.6 with 16384MB RAM
SHIGEO OYAMA に登録済み
AU plugin #0: エフェクト - Apple AUGraphicEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Mon Jun 6 23:12:52 2022
Library database path: /Users/oyamasigeo/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
D90 MQA
Model UID:D90 MQA:152A:8750
UID:AppleUSBAudioEngine:Topping:D90 MQA:fa130000:1
Active Sample Rate: 176.4kHz
ID 0x42 Duet USB Manufacturer:Apogee
Model UID:AppleUSBAudioDevice:Duet USB UID:AppleUSBAudioEngine:Apogee:Duet USB:fd140000:2,1
Audio buffer frame size : 53 to 4096 frames
Multichannel: 4 channels
Channel 2 mapped to 2
Channel 3 mapped to 3
Number of channels: 4
Simple stereo device: No
Number of active channels: 4, in 1 stream(s)
Stream ID 0x43 4 channels starting at 1
12 virtual formats:
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
4 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
12 physical formats
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 192kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 176.4kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 96kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 88.2kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 48kHz
4 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 44.1kHz
Device #0: ID 0x31 内蔵出力 Manufacturer: Apple Inc. Model UID: AppleHDA:32 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x42 Duet USB Manufacturer: Apogee Model UID: AppleUSBAudioDevice:Duet USB UID: AppleUSBAudioEngine:Apogee:Duet USB:fd140000:2,1
UPnP devices found : 1
Device #0: ID 0x0 寝室のテレビ UID: uuid:23456789-1234-1010-8000-94DB5624FCE8 Location: http://10.0.1.15:52323/MediaRenderer.xml
