I have used Audirvana 3.5 for a while and now I am evaluating Audirvāna Origin. I use a macmini connected to a Cambridge DacMagic 200 via USB.
I configured AUNBandEQ and entered the Eq parameters from REW; the Q numbers were converted to BW using a conversion calculator. I don’t notice any audio differences when I play music. This was also confirmed by REW measurements; the measurements are the same before and after entering the parameters in AUNBandEQ. The issue manifest in both 3.5 and Origin.
On a side note using AUGraphicEQ works as expected in both versions. I make changes in the equalizer and the changes are noticeable in the audio.
Perhaps I am missing something or I haven’t set a parameter in my Mac mini. Have anyone experience the same issues? Any idea what could be the problem?
Regards
