track loads ,just sits there not playing ,works ok with itunes ,was working fine ,.
Hello @bazzweb,
ok will do ,the problem seems to be switching from itunes back to Av eg AV dosent open i have to shut Av down and re-open it and the process interferes with midi controller output.
Audirvana Origin 1.0.5 (10005)
macOS 10.15.7 with 16GB physical RAM
Connected account of : barry clempson
Effects plugins ACTIVE in offline mode with legacy macOS API
AU plugin #0: Music Effect - MeldaProduction MConvolutionEZ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Replay Gain: by album
SW volume control: ON
AUTO: /Users/barry/Music/Music
iTunes/Music library synchronization: last synchronized on Tue Apr 6 18:45:53 2021
Library database path: /Users/barry/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51825
Max. memory for audio buffers: 4018MB
XMOS HIFI DSD
Model UID:HIFI DSD:20B1:0008
UID:AppleUSBAudioEngine:XMOS :HIFI DSD:14100000:1
Sample rate limitation: 48kHz
Sample rate switching latency: 1s
ID 0x31 HIFI DSD
Manufacturer: XMOS
Model Name: XMOS HIFI DSD
Model UID: HIFI DSD:20B1:0008
UID: AppleUSBAudioEngine:XMOS :HIFI DSD:14100000:1
Stream ID 0x32 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 6
Device #0: ID 0xd6 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0xdd HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:88 UID: AppleHDAEngineOutputDP:1B,3,1,0:0:{D94D-6604-01010101} Model Name: Apple Inc. HDMI
Device #2: ID 0x31 HIFI DSD Manufacturer: XMOS Model UID: HIFI DSD:20B1:0008 UID: AppleUSBAudioEngine:XMOS :HIFI DSD:14100000:1 Model Name: XMOS HIFI DSD
Device #3: ID 0x3a Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #4: ID 0x45 Soundflower (64ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:1 Model Name: ma++ ingalls for Cycling '74 Soundflower (64ch)
Device #5: ID 0x2a Multi-Output Device Manufacturer: Apple Inc. Model UID: ~:AMS2_StackedOutput:0 UID: ~:AMS2_StackedOutput:0 Model Name: Apple Inc. Multi-Output Device
UPnP devices found : 1
Device #0: ID 0x0 KDL-40WE663 UID: uuid:13c49eea-359c-11b2-be5b-38184c33f2e1 Location: http://192.168.1.116:2870/dmr.xml
Can you deactivate the use of plugins for testing and try to play a track again?
yes ,removing a unused plugin fixed the problem thanks .
