Connecting my AVM-Solution I have gaps every ten seconds using UPnP. On my MacBook itself all is working fine.
Whatˋs the cause for that?
Hello @Trimmelino,
Registriert nach Charlotte Helmstetter
No plugin active
AUTO: /Volumes/F2/
Library database path: /Users/charlotte/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: AVM Model UID:AVM Audio AVM UID:uuid:5F9EC1B3-ED59-79BB-4530-0011F6AB60DD
Currently playing to UPnP device at 24 bits 96kHz
UPnP device at http://192.168.178.29:8080/description.xml
ID 0x0 AVM Manufacturer:AVM Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/wav:*
http-get::audio/x-mpegurl:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/x-mpegurl:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
10 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:06:56
CurrentURI: http://192.168.178.20:49153/audirvana/audio_0_6.wav
CurrentURIMetadata: dc:title1. Agnus Dei</dc:title>upnp:artistBoris Allakhverdyan</upnp:artist>upnp:albumTigran Mansurian: Con anima</upnp:album>upnp:albumArtURIhttp://static.qobuz.com/images/covers/ra/lk/ns0w3m0y8lkra_600.jpg</upnp:albumArtURI>http://192.168.178.20:49153/audirvana/audio_0_6.wav
nextURI: http://192.168.178.20:49153/audirvana/audio_1_7.wav
nextURIMetadata: dc:title2. Qui tollis peccata mundi</dc:title>upnp:artistBoris Allakhverdyan</upnp:artist>upnp:albumTigran Mansurian: Con anima</upnp:album>upnp:albumArtURIhttp://static.qobuz.com/images/covers/ra/lk/ns0w3m0y8lkra_600.jpg</upnp:albumArtURI>http://192.168.178.20:49153/audirvana/audio_1_7.wav
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 AVM AVM Audio http://www.avm-audio.com AVM stream device AVM stream device model xxx http://www.avm-audio.com 0011F6AB60DD uuid:5F9EC1B3-ED59-79BB-4530-0011F6AB60DD 123810928305556upc urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt http://192.168.178.29:80/index.asp urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:0011F6AB60DDUPnP devices found : 1
Device #0: ID 0x0 AVM UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6AB60DD Location: http://192.168.178.29:8080/description.xml
Max. memory for audio buffers: 15360MB
Device #0: ID 0x30 Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:128 UID: AppleHDAEngineOutput:1B,0,1,1:0
I think you might consider contacting the manufacturer of your DAC because it announce that it can use DSD but the DSD rates are not available which is not normal as the information we get form your DAC are announced by it and we use it to determine the rates used by your DAC.
