Hello everyone.
I just wanna know if is possible balancing Permanently the exit R to left ajust a bit from Audirvana Origin ? Many thanks
Are you looking for something that will separately control the gain of the left and right channels? If so try this free plugin⦠Blue Cat's Gain Suite - Simple Mono, Stereo and Mid-Side MIDI Controllable Gain Plug-ins (VST, AU, VST3, AAX) (Freeware)
Could you please explaining how to use the plugin into Audirvana Studio?
I use Mac Os version, but I think will be the same on Windows o Mac .
Thank you
Press Show Settings, the 3 slider icon at the top right in Audirvanaā¦
Click the gear icon in the Processing block under Bufferizedā¦
Click the first dropdown area under Use Audio Units effects where it says No Effectā¦
Find and select the plug-in effect you wish to use⦠This assumes you have already installed the plug-in itself following the plug-in vendors instructionsā¦
You most likely want to enable the 3 switches, Use Audio Unit effects, Realtime control and Use New Audio Units MacOSā¦
Then click the Configure button next to your plug-in⦠Configure the plug-in as the vendors operating instructions suggest to your tasteā¦
Enjoy the musicā¦
