Hi,
i have issue with Audirvana Plus Trial version, installed yesterday on my Mac: I can not reroute the output music on my DAC Asus Xonar Essence One Headphone Output. The DAC is connected to the MAC thru the USB ports, & customized as Speaker USB on my MAC
I would appreciate your support, since i guess it is a basic set up error, but i am not so familiar neither with MAC Set Up, nor iTunes set up, nor Audianirvana Plus, nor my newly acquired DAC Asus.
I precize that the music output on my DAC was OK, thru the Headphone output, prior to installing Audirvana Plus Trial version on my MAC (and i have rebooted since);
My MAC preferences: Sound configuration was at that time with Speaker USB as Ouput
When i switch My MAC Sound configuration to Internal LoudSpeaker, type Integrated, --> Music is delivered thru the integrated loundspeakers of the MAC.
MAC Configuration at the moment, without no output to may DAC:
- MacBook Pro, 8 GB RAM, mid 2009 old, Intel Core 2 Duo, 2,53 GHZ, HDD
- Yosemite 10.10.5 (latest available on this model)
- MAC Preferences Sound configuration: Speaker / USB as Ouput
Audirvana Plus Preferences:
- in Audio System:
- when Prefrerred Audio Peripheric: Integrated output -->music in Mac Loudspeakers
- when Prefrerred Audio Peripheric: Speaker --> no music neither in DAC headphoen output nor in Mac Loudspeakers & error msg: Failure in gaining exclusive access OSError = hog!
iTunes Preferneces: no change done on initial configuration.
–> Result: no sound in my Headphone output of the DAC, but Music is delivered thru the integrated loundspeakers of the MAC
Any help will be appreciated. Thanks a lot
