Hello, sorry for being late to respond to this.
Using:
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.2 with 16384MB RAM
…I can no longer re-produce the issue I observed earlier. I did notice that you implemented some UPnP / DLNA fixes for a customer with a Pioneer streamer, so maybe that repaired things for the Bel Canto Stream, as well.
The only issue I am now observing is that if I start playback of an album or playlist, and then navigate to another album or playlist and start playback (click on the small > button next to a track), playback can stop entirely, play the next track from the previous playlist/album or output a static sound from the streamer (like FM radio white noise).
If I explicitly STOP playback, I can restart from another playlist and everything is fine.
I have attached the debug output if that helps. Thanks, Ken
Registered to Kenneth Krutsch
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 32%
Sync list: 3 folders
AUTO: /Volumes/LaCie/My DLNA Extras/Surround DLNA
AUTO: /Volumes/LaCie/My DLNA Music
AUTO: /Volumes/LaCie/Qobuz
Library database path: /Users/ken/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: e.One Stream-Krutsch Model UID:Bel Canto Design e.One Stream-Krutsch UID:uuid:52A92946-067B-121B-B9BE-985E1B004583
UPnP device at http://192.168.1.219:38418/description.xml
ID 0x0 e.One Stream-Krutsch Manufacturer:Bel Canto Design
Volume control: No
http-get::audio/mp4:DLNA.ORG_PN=MP4
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/x-sony-oma:DLNA.ORG_PN=ATRAC3plus
http-get::audio/aiff:
http-get::audio/wav:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/ac3:
http-get::audio/x-dsf:
http-get::audio/x-wav:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:04:25
CurrentURI: http://192.168.1.155:49152/audirvana/audio_0_9.wav
CurrentURIMetadata:
dc:titleEdge Of The Ocean</dc:title>
dc:creatorIvy</dc:creator>
upnp:artistIvy</upnp:artist>
upnp:genreIndie Pop</upnp:genre>
upnp:albumArtURIhttp://192.168.1.155:49152/audirvana/artwork_0_10.jpg</upnp:albumArtURI>
upnp:albumLong Distance</upnp:album>
upnp:originalTrackNumber3</upnp:originalTrackNumber>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
<?xml version="1.0"?>
1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
Stop
InstanceID
in
GetCurrentTransportActions
InstanceID
in
Actions
out
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
Next
InstanceID
in
Pause
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Previous
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
CurrentPlayMode
string
NORMAL
REPEAT_ALL
REPEAT_ONE
SHUFFLE
NORMAL
RecordStorageMedium
string
NOT_IMPLEMENTED
LastChange
string
string
CurrentTrackURI
string
string
string
NOT_IMPLEMENTED
string
i4
i4
ui4
AVTransportURI
string
TransportState
string
STOPPED
PAUSED_PLAYBACK
PLAYING
TRANSITIONING
NO_MEDIA_PRESENT
string
NextAVTransportURI
string
string
CurrentTrack
ui4
0
4294967295
1
string
string
string
string
string
WRITABLE
PROTECTED
NOT_WRITABLE
UNKNOWN
NOT_IMPLEMENTED
string
string
NumberOfTracks
ui4
0
4294967295
A_ARG_TYPE_SeekMode
string
TRACK_NR
REL_TIME
ABS_COUNT
string
string
TransportStatus
string
OK
ERROR_OCCURRED
vendor-defined
TransportPlaySpeed
string
1
vendor-defined
1
0
Bel Canto Design
http://www.conversdigital.com
This model is a connected audio module which supports the UPnP/DLNA standard
Stream
CDMCM-210-001
DMR-1.50
image/png
48
48
24
/images/small.png
image/png
120
120
24
/images/large.png
image/jpeg
48
48
24
/images/small.jpg
image/jpeg
120
120
24
/images/large.jpg
/service/RenderingControl1.xml
/service/RenderingControl_control
/service/RenderingControl_event
/service/ConnectionManager1.xml
/service/ConnectionManager_control
/service/ConnectionManager_event
/service/AVTransport1.xml
/service/AVTransport_control
/service/AVTransport_event
CDM212104180452
UPnP devices found : 4
Device #0: ID 0x0 [TV] Samsung 7 Series (55) UID: uuid:4fb2850b-4952-4a51-82e5-65cc9d497dbc Location: http://192.168.1.241:9197/dmr
Device #1: ID 0x0 Pioneer DMR UID: uuid:140479c0-58f3-1cef-84bf-745e1c19d96f Location: http://192.168.1.231:2870/62FD_dmr.xml
Device #2: ID 0x0 Pioneer VSX-1122-K UID: uuid:5F9EC1B3-ED59-79BB-4530-745E1C127E75 Location: http://192.168.1.230:8080/description.xml
Device #3: ID 0x0 e.One Stream-Krutsch UID: uuid:52A92946-067B-121B-B9BE-985E1B004583 Location: http://192.168.1.219:38418/description.xml
Max. memory for audio buffers: 2048MB
Local devices found : 4
Device #0: ID 0x67 Bel Canto uLinkUSB 2.0 Audio Out Manufacturer: Bel Canto uLink Model UID: Bel Canto uLinkUSB Audio 2.0:2646:0002 UID: AppleUSBAudioEngine:Bel Canto uLink:Bel Canto uLinkUSB Audio 2.0:0000:1
Device #1: ID 0x62 Elgato Dock Manufacturer: Burr-Brown from TI Model UID: USB audio CODEC:08BB:2912 UID: AppleUSBAudioEngine:Burr-Brown from TI:Elgato Dock:1400000:1
Device #2: ID 0x52 MacBook Air Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #3: ID 0x2c ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001
