Plenty of ground loop noise is coming from my PC. Some DACs (like, Chord Mojo) do pick this up, and I can hear that noise in the speakers.
Actually, when I connected USB from the front of that PC there was MUCH less noise, but when I play DSD files via Audirvana of Foobar2000, some whistle comes out of speakers when USB is connected this way.
I use MacBook Pro (late 2017) for my main system and tested it with another to see if that noise will be there. But not only the noise gone, the sound is also noticeably better. Both machines have Audirvana installed and I tried them with the same USB cable.
I even tried iFi iSilencer+ USB Audio Noise Eliminator which resulted to even more noise! But it’s probably wrong device as when I bought it I didn’t know it’s a ground loop noise. I knew that after doing more research and running some tests.
Could be due to an old motherboard and the power supply?
My other DACs, like PS Audio DS DAC and Gain Cell DAC don’t pick that noise, are they ignoring/filtering it? I don’t know, but if it’s there, maybe it’s somehow affecting the music signal? If someone knows, please, share your thoughts.
Also, using Avantree Leaf USB Bluetooth Audio Transmitter with the same PC hooked up with Audioengine B1 Bluetooth 5.0 Music Receiver gives quite amazing (to my ears) result and there is zero of that same noise via both RCA or Optical outputs of the BT receiver.
Anyway, my MacBook Pro sounds better to me than my old PC, but I am not sure if a newer PC will sound as bad as my 2012 built PC with even older replacement of it’s Motherboard.
So I am also thinking, whether to buy another Mac for Music, or cheaper, but more contemporary Windows based PC, because I don’t like what I hear from my current PC.
