Good day all,
I am new to Audirvana. From the start, I found the sound superior to listen to TIdal with Audirvana vs listening to Tidal directly from the Tidal application on my DAC (Singer SDA-2c) USB connected to my computer.
I try to establish the best settings for listening to Tidal and more precisely the MQA files.
I have a DAC (non-MQA renderer or decoder a Singxer SDA-2, advanced) connected via USB to a computer, but it supports DSD up to DSD512.
Currently I am listening to TIDAL files with the parameter set to upsampling DSD512.
Then all TIDAL files (FLAC or MQA) are upsampling to DSD512. My computer (i7, 16GIG of RAM has no difficulty managing upsampling in DSD512).
Is this the best setting for sound quality?
Could I have a setting to BIT PERFECT for MQA files only (assuming Audirvana will do the first processing of MQA files)?
Thanks in advance for your recommendations!
