Hi All,
I like very much the vast collection of classical music files in Qobuz, but using Studio, the same Hi-Res file sounds much better played on Radio France Musique than Qobuz.
Bizarre, no ?
Are they better alternatives to Qobuz beside DG, purchasing Hi-res files, … ?
Thanks for your supoort
Which Radio France Musique stream/station are you referring to?
This is the name of the radio, In Audi, ook under Radios/Country or Language or High quality and search for its name…
German Hi-res radios are also fine and probably others…
Kind regards,
Thank you for the link, I will try it.
Kind regards
