macOS 11.2.3 with 8192MB RAM
Registered to Alexander Hauskrecht
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
SW volume control: ON
Sync list: 2 folders
AUTO: /Volumes/music/
AUTO: /Users/alexanderhauskrecht/Music
Library database path: /Users/alexanderhauskrecht/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
S801PM
Model UID:99a 500
UID:f4-4e-fd-42-d6-6c:output
Active Sample Rate: 48kHz
ID 0x58 S801PM Manufacturer:99a
Model UID:99a 500 UID:f4-4e-fd-42-d6-6c:output
1 available sample rates up to 48000Hz
Audio buffer frame size : 15 to 3840 frames
Stream ID 0x59 2 channels starting at 1
1 virtual formats:
1 physical formats
Device #0: ID 0x4c Reproduktory MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #1: ID 0x58 S801PM Manufacturer: 99a Model UID: 99a 500 UID: f4-4e-fd-42-d6-6c:output
UPnP devices found : 2
Device #0: ID 0x0 Denon AVR-X3100W UID: uuid:5f9ec1b3-ff59-19bb-8530-0005cd41e7c2 Location: http://192.168.0.12:8080/description.xml
Device #1: ID 0x0 280D MiND 2 Living Room UID: uuid:07f5febb-f99d-4a7b-808a-ef8574145361 Location: http://192.168.0.68:39330/07f5febb-f99d-4a7b-808a-ef8574145361.xml
