I have been running Audirvana on one system with a Mac and outputting to a USB DAC. I’m looking to setup another system in seperate room using a bluesound node 2i. I’m seeing conflicting info on using Audirvana with the Node 2i. I had hoped to be able to either A connect direct to pc via usb like I do with my other dac and output Audirvana to it usb or connect to it via WiFi or Ethernet. Is this not possible?
hi, did you solve this? I had the same issue first with 2i and now with M10 - thanks
The only way to connect to Bluesound devices is AirPlay.
thanks i’ll research this but not sure apple have MQA
