Blurry cover art and UI bug
I just started using Audirvana Origin (MacOS Tahoe) and after adding my library, some cover arts look all blurred:
This also happens with album covers, and when that is the case, opening an artist results in this visual bug:
ScreenRecording2026-04-06at8.16.55p.m.-ezgif.com-video-to-gif-converter
I have tried deleting the local database, reinstalling Origin, and even redownloading all of my library from Google Drive but nothing seemed to make a difference. This is something that happens with Studio too.
The first time I opened Origin was when all of the files where being downloaded with the Google Drive app which is what I think caused the issue. So my theory is that there is some cache that I am not deleting and is persisting even after erasing the app with something like AppCleaner.
Note: I have opened the cover art files directly from finder and they seem to be fine.
Any help or insights would be greatly appreciated!
Can you please try to edit this cover by opening the artist and then opening the metadata editor to change the picture?
Hi @facund015
I have found this “blurry” image issue. On some albums. Just added two and on OK the next blurred. To fix I replace with the same image and the blurr is fixed..
Regards
Phil
Hi @philipjohnson,
Thank you! It did get fixed by just replacing the cover.
Hi @facund015
This issue has not been solved.
It has been an intermittent fault for many months. Since Beta 3 I think. Annoying but what the… fantastic sound.
Phil
Hi @philipjohnson ,
Ohh that’s a bummer, but yeah I agree, the sound makes it worth it.
