has anyone been able to use audirvana with the bose soundtouch 10. it has a wireless upnp interface. the problems i’ve encountered include:
- unable to find the device
- you can start a track (both local file and tidal) and it spins up and stops right away and then the control panel becomes unresponsive.
- if you luck out and get it to play a track, it stops at the end. you manually need to advance to the next track.
for the record, the soundtouch app that runs on my mac is able to stream to the device with few issues, which means the connection is there and the remote device works.
