Hi, I’m having issues with Audirvana MAC playing through my Bose Soundtouch, it plays sporadically, I cannot find the reason why sometimes works and sometimes don’t. I reboot the computer, reboot Audirvana but no help. Below is the debug information, please help!
David Guevara
macOS 11.1.0 with 16384MB RAM
Registered to DAVID A GUEVARA
AUTO: /Volumes/MAC Media/FLAC COLLECTION
Library database path: /Users/davidguevara/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: David ST Model UID:Bose Corporation David ST UID:uuid:BO5EBO5E-F00D-F00D-FEED-E8EB11BEC09D
UPnP device at http://192.168.0.102:8091/XD/BO5EBO5E-F00D-F00D-FEED-E8EB11BEC09D.xml
ID 0x0 David ST Manufacturer:Bose Corporation
Volume control: No
http-get::audio/mpeg:*
http-get::audio/mp3:
http-get::MP3:
http-get::audio/x-ms-wma:
http-get::audio/wma:
http-get::WMA:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ogg:
http-get::application/ogg:
http-get::audio/vorbis:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/mp4:
http-get::audio/mpeg4-generic:
http-get::audio/aac:
http-get::audio/x-aac:
http-get::audio/x-m4a:
http-get::audio/aacp:
http-get::audio/3gpp:
http-get::audio/3gpp2:
http-get::audio/vnd.apple.mpegurl:
http-get::audio/vnd.apple.mpegurl.audio:
http-get::application/mpegurl:
http-get::application/x-mpegurl:
http-get::audio/mpegurl:
http-get::audio/x-mpegurl:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
30 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:04:28
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> TransportState no string STOPPED PLAYING TRANSITIONING PAUSED_PLAYBACK NO_MEDIA_PRESENT TransportStatus no string OK ERROR_OCCURRED CurrentMediaCategory no string NO_MEDIA TRACK_AWARE TRACK_UNAWARE PlaybackStorageMedium no string RecordStorageMedium no string PossiblePlaybackStorageMedia no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed no string 1 RecordMediumWriteStatus no string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 CurrentTrack no ui4 0 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no ui4 CurrentTransportActions no string LastChange yes string DRMState no string OK UNKNOWN SyncOffset no string A_ARG_TYPE_SeekMode no string TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 A_ARG_TYPE_DeviceUDN no string A_ARG_TYPE_ServiceType no string A_ARG_TYPE_ServiceID no string A_ARG_TYPE_StateVariableValuePairs no string A_ARG_TYPE_StateVariableList no string A_ARG_TYPE_SyncOffsetAdj no string A_ARG_TYPE_PresentationTime no string A_ARG_TYPE_ClockId no string A_ARG_TYPE_PlaylistData no string A_ARG_TYPE_PlaylistOffset no ui4 A_ARG_TYPE_PlaylistDataLength no ui4 A_ARG_TYPE_PlaylistTotalLength no ui4 A_ARG_TYPE_PlaylistMIMEType no string A_ARG_TYPE_PlaylistExtendedType no string A_ARG_TYPE_PlaylistStep no string Initial Continue Stop Reset A_ARG_TYPE_PlaylistType no string Static Streaming A_ARG_TYPE_PlaylistInfo no string A_ARG_TYPE_PlaylistStartObjID no string A_ARG_TYPE_PlaylistStartGroupID no string SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Record InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode SetRecordQualityMode InstanceID in A_ARG_TYPE_InstanceID NewRecordQualityMode in CurrentRecordQualityMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDRMState InstanceID in A_ARG_TYPE_InstanceID CurrentDRMState out DRMState GetStateVariables InstanceID in A_ARG_TYPE_InstanceID StateVariableList in A_ARG_TYPE_StateVariableList StateVariableValuePairs out A_ARG_TYPE_StateVariableValuePairs SetStateVariables InstanceID in A_ARG_TYPE_InstanceID AVTransportUDN in A_ARG_TYPE_DeviceUDN ServiceType in A_ARG_TYPE_ServiceType ServiceId in A_ARG_TYPE_ServiceID StateVariableValuePairs in A_ARG_TYPE_StateVariableValuePairs StateVariableList out A_ARG_TYPE_StateVariableList AdjustSyncOffset InstanceID in A_ARG_TYPE_InstanceID Adjustment in A_ARG_TYPE_SyncOffsetAdj GetSyncOffset InstanceID in A_ARG_TYPE_InstanceID CurrentSyncOffset out SyncOffset SetSyncOffset InstanceID in A_ARG_TYPE_InstanceID NewSyncOffset in SyncOffset SyncPlay InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed ReferencePositionUnits in A_ARG_TYPE_SeekMode ReferencePosition in A_ARG_TYPE_SeekTarget ReferencePresentationTime in A_ARG_TYPE_PresentationTime ReferenceClockId in A_ARG_TYPE_ClockId SyncPause InstanceID in A_ARG_TYPE_InstanceID PauseTime in A_ARG_TYPE_PresentationTime ReferenceClockId in A_ARG_TYPE_ClockId SyncStop InstanceID in A_ARG_TYPE_InstanceID StopTime in A_ARG_TYPE_PresentationTime ReferenceClockId in A_ARG_TYPE_ClockId SetStaticPlaylist InstanceID in A_ARG_TYPE_InstanceID PlaylistData in A_ARG_TYPE_PlaylistData PlaylistDataLength in A_ARG_TYPE_PlaylistDataLength PlaylistOffset in A_ARG_TYPE_PlaylistOffset PlaylistTotalLength in A_ARG_TYPE_PlaylistTotalLength PlaylistMIMEType in A_ARG_TYPE_PlaylistMIMEType PlaylistExtendedType in A_ARG_TYPE_PlaylistExtendedType PlaylistStartObj in A_ARG_TYPE_PlaylistStartObjID PlaylistStartGroup in A_ARG_TYPE_PlaylistStartGroupID SetStreamingPlaylist InstanceID in A_ARG_TYPE_InstanceID PlaylistData in A_ARG_TYPE_PlaylistData PlaylistDataLength in A_ARG_TYPE_PlaylistDataLength PlaylistMIMEType in A_ARG_TYPE_PlaylistMIMEType PlaylistExtendedType in A_ARG_TYPE_PlaylistExtendedType PlaylistStep in A_ARG_TYPE_PlaylistStep GetPlaylistInfo InstanceID in A_ARG_TYPE_InstanceID PlaylistType in A_ARG_TYPE_PlaylistType PlaylistInfo out A_ARG_TYPE_PlaylistInfoCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 David ST QPlay:2 Bose Corporation http://www.bose.com SoundTouch 20 Bose SoundTouch Wireless Streaming Audio Device http://www.bose.com E8EB11BEC09D uuid:BO5EBO5E-F00D-F00D-FEED-E8EB11BEC09D urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /Xml/AVTransport3.xml /AVTransport/Control /AVTransport/Event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /Xml/ConnectionManager3.xml /ConnectionManager/Control /ConnectionManager/Event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /Xml/RenderingControl3.xml /RenderingControl/Control /RenderingControl/Event urn:schemas-tencent-com:service:QPlay:2 urn:tencent-com:serviceId:QPlay /QPlay/Control /QPlay/Event /Xml/QPlay.xmlUPnP devices found : 1
Device #0: ID 0x0 David ST UID: uuid:BO5EBO5E-F00D-F00D-FEED-E8EB11BEC09D Location: http://192.168.0.102:8091/XD/BO5EBO5E-F00D-F00D-FEED-E8EB11BEC09D.xml
Device #0: ID 0x4c MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
