Hi I have a BOSE Soundtouch and i was able to play my music from my MAC, suddenly is no longer working. Please help!
Hello @dguevara1,
thank you for responding, , The issue with the soundtouch has been resolved. The issue i have now is the synching in windows, i turned on the synching at start however it keeps synching all the time and makes the application slow. This issue is in windows, the application in my Mac is fine
Thanks you
Audirvana 3.5.43
VST3 plugin #0: C:\Program Files\Common Files\VST3\SonEQFree.vst3
ClassID: F2AEE70D00DE4F4E536F6E69536F4551
VST3 plugin #1: None
VST3 plugin #2: None
VST3 plugin #3: None
AUTO: D:\FLAC COLLECTION
Library database path: D:\FLAC COLLECTION\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3886MB
Local Audio Engine:WASAPI
Speaker (Realtek® Audio)
Model UID:Speaker (Realtek® Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b2707964-a07e-4abc-93d4-6767f7538a27}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speaker (Realtek® Audio) Manufacturer:
Model UID:Speaker (Realtek® Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{b2707964-a07e-4abc-93d4-6767f7538a27}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 44.1kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 48kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 88.2kHz
2 ch Integer PCM 20bit little endian aligned high in 32bit chunk 88.2kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 96kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 176.4kHz
2 ch Integer PCM 20bit little endian aligned high in 32bit chunk 176.4kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 192kHz
Device #0: Speaker (Realtek® Audio) Manufacturer: Model UID: Speaker (Realtek® Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{b2707964-a07e-4abc-93d4-6767f7538a27}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
UPnP devices found : 1
Device #0David ST UID: uuid:BO5EBO5E-F00D-F00D-FEED-E8EB11BEC09D Location: http://192.168.0.102:8091/XD/BO5EBO5E-F00D-F00D-FEED-E8EB11BEC09D.xml
Hello @dguevara1,
Your Audirvana database is located where your tracks are located, this is why it’s slow and Audirvna is syncing. Can you move the database to a different location?
I changed the location of the database to another folder however now i can not rate, set favorites, in the setting i changed to scan when open the application, it reverted back. So anything i do dont work anymore. Any suggestions? i already created several playlists and i still have more track to rate set favorites, etc, etc… i Have a lot of music.
Thanks!
