Bowers & Wilkins A7 UPnP - fail/solution?
Hi all
I’ve a Bowers & Wilkins A7 (now neo-ancient tech) that I can connect either wirelessly or wired and is ‘seen’ by Audirvana as a UPnP endpoint (appears on list) but, crucially says connected when selected but then drops, goes to default system output and doesn’t play. Any help or thoughts please? Much appreciated. Using Mac/Origin.
Can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button; click on it and reproduce your issue. After you reproduce it, click 'Stop Log Session’ and open the audirvana_origin.log file you can find by clicking the 'Open Log Folder’ button.
Thanks Antoine I’ve sent a dm with log.
