Bricasti M5
UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 175,4 - 192
DSD supported sample rate : 64 - 128
DSD Over PCM setting : None
MQA capability : No
Volume:
Volume can be changed : No
Device can mute - unmute: No
Playback:
Best upsampling setting for device : None
Setting do not send RAW PCM activated : No
Playback Control:
Gapless playbak option enabled : No
Please, can you shed some light on why the M5 does not support a higher PCM sample rate than 192?
AFAIK, the M5 uses the same streaming board as the Bricasti DACs.
Thx
Matt
It is stated on their website:
