Hi
When playing the first track in a listening session, within the first 1 minute or so, the music pauses/mutes for approximately 1 second, then resumes. This occurs anywhere from 10 to 70 seconds track elapsed time. I’ve tried changing between 4Gb, 6Gb and 12Gb for track pre-load and it doesn’t seem to have any impact on the problem. I haven’t noticed this problem on our two other computer setups (1. 2023 MacBook Air/Topping D10s/Anthem MRX710, and 2. 2020 iMac 27" / Focusrite Clarett 2 Pre).
Here’s the Debug Info:
Audirvana Origin 2.4.0 (20400)
macOS Version 13.6 (Build 22G120) with 16GB physical RAM
Connected account of : Tim Stapleton
AUTO: /Volumes/T&C SSD4 2TB Audio Library/Audio Library T&C
Library database path: /Users/tandc/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49287
Max. memory for audio buffers: 6000MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Topping D10s
Model UID:D10s:152A:8750
UID:AppleUSBAudioEngine:Topping:D10s:100000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
Limit bitdepth to 24bit: ON
Selected device:D10s
Manufacturer: Topping
Model name: Topping D10s
Model UID: D10s:152A:8750
UID: AppleUSBAudioEngine:Topping:D10s:100000:1
USB Vendor ID: 0x152a
USB Product ID: 0x8750
ID 0x31
Max volume alert: Disabled
Stream ID 0x32 2 channels starting at 1
24 virtual formats:
32 physical formats
Local devices found : 3
Device #0: ID 0x37 MRX 740
Manufacturer: ATM
Model UID: 068D0100-0000-0000-001E-010380000078
Model name: ATM MRX 740
Device #1: ID 0x31 D10s
Device #2: ID 0x59 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 : MRX 740
UID: uuid:8ec6e5c5-f1b0-4800-9fe3-092c77eac6c3
Location: http://192.168.0.250:42125/8ec6e5c5-f1b0-4800-9fe3-092c77eac6c3.xml
Manufacturer: Anthem
Model name: MRX 740
Chromecast devices found : 1
Device #0: MRX 740
Model name: MRX 740
