Bonjour,
Après migration de Audirvana 3.5 à Audirvana Studio et sur certaine pistes, un bruit blanc/larsen dès le début du morceau et en continu.
Merci !
JMB
Audirvana Studio 1.14.0 (11400)
macOS 12.5.1 with 32GB physical RAM
Connected account of : Jean-Marc Badaroux
Per track: OFF
Replay Gain: by track
SW volume control: ON
Sync list: 0 folders
Library database path: /Users/jmb/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50530
CoreAudio audio path, buffer I/O frame size: 4096
TC Near
Model UID:TCNear:DICE Device
UID:TCNearAudioEngine:0
Device: 6ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 24 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x54 TC Near
Manufacturer: TC Electronic
Model Name: TC Electronic TC Near
Model UID: TCNear:DICE Device
UID: TCNearAudioEngine:0
Multichannel: 6 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Number of channels: 6
Simple stereo device: No
Number of active channels: 6, in 1 stream(s)
Stream ID 0x55 6 channels starting at 1
6 virtual formats:
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
6 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
6 physical formats
6 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 192kHz
6 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 176.4kHz
6 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz
6 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz
6 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz
6 ch Mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
Local devices found : 3
Device #0: ID 0x45 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:130 UID: AppleHDAEngineOutput:1F,3,0,1,2:0 Model Name: Apple Inc. Sortie intégrée
Device #1: ID 0x2d Microsoft Teams Audio Manufacturer: Microsoft Corp. Model UID: MSLoopbackDriverDevice_ModelUID UID: MSLoopbackDriverDevice_UID Model Name: Microsoft Corp. Microsoft Teams Audio
Device #2: ID 0x54 TC Near Manufacturer: TC Electronic Model UID: TCNear:DICE Device UID: TCNearAudioEngine:0 Model Name: TC Electronic TC Near
UPnP devices found : 1
Device #0: ID 0x0 décodeur TV 4 UID: uuid:00ababad-7947-1048-8a00-3c17100abcc5 Location: http://192.168.1.11:42300/description.xml
