Do you have this behavior if you try with this output selected in Audirvāna? ![]()
I haven’t tested it from the speakers.
Here’s another sudden stop when playing the penultimate track.
Audirvana Origin 2.5.10 (20510)
macOS Version 13.5 (Build 22G74) with 8GB physical RAM
Connected account of : Андрей Начаров
AUTO: /Volumes/T7/
Library database path: /Users/andrejnacarov/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 51604
Max. memory for audio buffers: 2018MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Amanero Technologies Combo384 Amanero
Model UID:Combo384 Amanero:16D0:071A
UID:AppleUSBAudioEngine:Amanero Technologies:Combo384 Amanero:413-001:2
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
Sample rate switching latency: 0.5s
Selected device:Combo384 Amanero
Manufacturer: Amanero Technologies
Model name: Amanero Technologies Combo384 Amanero
Model UID: Combo384 Amanero:16D0:071A
UID: AppleUSBAudioEngine:Amanero Technologies:Combo384 Amanero:413-001:2
USB Vendor ID: 0x16d0
USB Product ID: 0x071a
ID 0x31
32000
Max volume alert: Disabled
DSD via PCM 1.1
Stream ID 0x32 2 channels starting at 1
18 virtual formats:
18 physical formats
Device #0: ID 0x31 Combo384 Amanero
Device #1: ID 0x4e Динамики Mac mini
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Динамики Mac mini
So that you can reproduce the problem.
I’m recording an album on cassette.
Let’s say from the first to the third track, then I pause the playback.
I turn on the penultimate track and listen to the volume level during recording; if it suits me, I return to the beginning of the track with the button and start playback.
1-2 seconds before the end, playback is interrupted, stops and the last track does not play.
A very annoying error, since the stopped track has to be recorded again.
I haven’t seen anything like this before version 2.5.7.
Bug at song finishing
Even after the last update the BUG continues.
It doesn’t happen on all tracks, but it still happens mostly on DSD.
