Hello! I have multiple issues with Crave EQ Plugin.
Character encoding issue. Observe the screenshot below. I have no issue using the same plugin with SoundSource.
Unable to save preset to ‘Local’. I have configured full disk access in macOS settings.
I’m able to save presets to ‘User’. But I’d like to add custom-made presets which I made before. I couldn’t find a button to import new presets, so if I need a ‘User’ location path to add them manually with Finder. Please provide the path. I wasn’t able to find it by myself.
Debug info:
Audirvana Studio 1.7.2 (10702)
macOS Version 11.6 (Build 20G165) with 16GB physical RAM
Connected account: squad.gazzz@gmail.com (Ilya Zhavoronkov)
AU plugin #0: Effect - Crave DSP Crave EQ 2 ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 0 folders
Library database path: /Users/izhavoronkov/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 52896
Max. memory for audio buffers: 5082MB
iFi (by AMR) HD USB Audio Output
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
Active Sample Rate: 96kHz
ID 0x69 iFi (by AMR) HD USB Audio Output
Manufacturer: iFi (by AMR)
Model Name: iFi (by AMR) HD USB Audio Output
Model UID: iFi (by AMR) HD USB Audio:20B1:3008
UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1
MQA Renderer device
Stream ID 0x6a 2 channels starting at 1
16 virtual formats:
16 physical formats
Local devices found : 4
Device #0: ID 0x69 iFi (by AMR) HD USB Audio Output Manufacturer: iFi (by AMR) Model UID: iFi (by AMR) HD USB Audio:20B1:3008 UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:00000000:1 Model Name: iFi (by AMR) HD USB Audio Output
Device #1: ID 0x5e Внешние наушники Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice Model Name: Apple Inc. Внешние наушники
Device #2: ID 0x52 Динамики MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Динамики MacBook Pro
Device #3: ID 0x2e Multi-Output Device Manufacturer: Apple Inc. Model UID: ~:AMS2_StackedOutput:0 UID: ~:AMS2_StackedOutput:0 Model Name: Apple Inc. Multi-Output Device
