hello Agoldnear
i have done what you suggested:
-1/ I restarted the mac(with usb), and the DAC, and all the stereoâŠ
-2/ audio midi settings is on the usb dac outputs
-3/ Iâve put the playback preload memory(âmemoire tamponâ in french) to 4 GO, instead of 10 GO(i donât know how it change the result, but maybe you can explain that to me ! )
Then now it seems to work well again: i can change my albums or any music and the system doesnât âbugâ anymore;
The sound is good on my loudspeakers.* i listen too with (very goods)CD player, vinyl turntable, analog tuner, so i will now compare a little bit more with the streaming sound on studioâŠ
-3/ iâve tested after closing the eq mac (in the settings of studio), and with it : apparently it does not change something .
i probably will buy the equalizer that you suggest to me(but for the moment it is not possible to do the payment on their internet space !)
Anyway, for listening on my stereo system generally i donât use equalization (except on" flat!" )
for your information, i have 2 mac book pro(they are same models); i use one of them only for listening music on my stereo , with usb and dac (Audiomat maestro); so the only test iâve done last time with the other one ,was done with its computer speakers: but i donât use it generallyâŠ
Now i will try to well understand how all the studio set up works⊠i will probably ask it by mail to the Audirvana staff.
Thanks a lot for your help
i put the last debug info below: Tell meâŠ
Audirvana Studio 2.9.4.1 (20905)
macOS 12.7.6 x86_64 with 16GB physical RAM
Connected account of : Gilles Dentan
AU plugin #0: Effet - Apple AUGraphicEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
r8brain with 2x upsampling
Max allowed volume: 1.15453
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Fri Nov 29 12:52:40 2024
Library database path: /Users/gillesdentan1/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 1613
Listening on 127.0.0.1 on port 51964
TIDAL: Connected as PREMIUM
Font size: regular
Language: Langue du systĂšme
Ma Musique
Radios
Podcasts
Streaming
Startup view: Ma Musique : Albums
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: yes
Max. memory for audio buffers: 4074MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Burr-Brown from TI USB Audio DAC
Model UID:USB Audio DAC :08BB:2704
UID:AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14120000:1
Selected device:USB Audio DAC
Manufacturer: Burr-Brown from TI
Model name: Burr-Brown from TI USB Audio DAC
Model UID: USB Audio DAC :08BB:2704
UID: AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14120000:1
USB Vendor ID: 0x08bb
USB Product ID: 0x2704
ID 0x34
3 available sample rates up to 48000Hz
32000
Stream ID 0x35 2 channels starting at 1
12 virtual formats:
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
12 physical formats
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Local devices found : 3
Device #0: ID 0x41 Sortie intégrée
Model UID: AppleHDA:94
Model name: Apple Inc. Sortie intégrée
Device #1: ID 0x34 USB Audio DAC
Device #2: ID 0x2c eqMac
Manufacturer: Bitgapp Ltd
Model UID: EQMDeviceModelUID
UID: EQMDevice
Model name: Bitgapp Ltd eqMac
