I am a user of Audrivana since version 1.X and the DSD playback work on my ExD USB Bac without fault. Recently, i have updated my DAC to a new model of the same manufacturer. I found that despite the menu show the driver support DSD playback but the DSD playback had never work. The DSD Native Streaming Method selection in the preference section had disappeared in the preference menu under the new DAC USB driver By chance, I plug the same MAC computer to another USB DAC ( Xmos based 9038) and found that the selection re-appear again and had by default change to āConvert to PCMā . I had manually converted back to DOP 1.0 and replug the USB cable into the new ExD USB DAC, the DSD playback is now working perfectly. To me, it looks like that there is a bug in identifiying the correct USB driver and change to a default which disable the USB playback. Will it be possible to fix this issue as you do not expect to have another USB DAC to make it work. I had enclosed the debug information for your reference.
Registered to Anthony Lee
AUTO: /Volumes/DS1520/Music
Library database path: /Users/amhlee/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
exD USB Audio 2.0
Model UID:exD USB Audio 2.0:ABCD:0008
UID:AppleUSBAudioEngine:exD :exD USB Audio 2.0:14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 32bits little endian Signed Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
ID 0x4a exD USB Audio 2.0 Manufacturer:exD
Model UID:exD USB Audio 2.0:ABCD:0008 UID:AppleUSBAudioEngine:exD :exD USB Audio 2.0:14100000:1
Stream ID 0x4b 2 channels starting at 1
16 virtual formats:
16 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x4a exD USB Audio 2.0 Manufacturer: exD Model UID: exD USB Audio 2.0:ABCD:0008 UID: AppleUSBAudioEngine:exD :exD USB Audio 2.0:14100000:1
UPnP devices found : 1
Device #0: ID 0x0 KD-49X8500F UID: uuid:23456789-1234-1010-8000-CC988BC99749
