Thanks for the answer. I didn’t know about your contact with Qobuz. This makes me happy. My debug info:
Audirvana Mac Version 1.6.4 (10604)
Connected account: *****************************
Bandwidth at 0dB = 99.5%
Phase = 66%
SW volume control: ON
AUTO: /Users//Downloads/[32.192] PINK FLOYD WISH YOU WERE HERE_38_ЛЕНТА [frfr;t]
Library database path: /Users/***/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 54833
Max. memory for audio buffers: 8000MB
SMSL SMSL USB AUDIO
Model UID:SMSL USB AUDIO:152A:85DD
UID:AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:fd120000:1
Active Sample Rate: 48kHz
ID 0x2a SMSL USB AUDIO
Manufacturer: SMSL
Model Name: SMSL USB AUDIO
Model UID: SMSL USB AUDIO:152A:85DD
UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:fa130000:1
Stream ID 0x2b 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 3
Device #0: ID 0x36 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:29 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x48 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:29 UID: AppleHDAEngineOutputDP:0,1,0,1,0:0:{0C41-C100-00004D58} Model Name: Apple Inc. HDMI
Device #2: ID 0x2a SMSL USB AUDIO Manufacturer: SMSL Model UID: SMSL USB AUDIO:152A:85DD UID: AppleUSBAudioEngine:SMSL:SMSL USB AUDIO:fa130000:1 Model Name: SMSL USB AUDIO
