Hi, I’m testing out Audirvana and it was working fine for half an hour and then suddenly there was very loud static, loud enough to damage my ears or headphones. I quickly paused, changed tracks and when I started again it was still just static so I closed the app.
I was streaming to my DAC’s internal streamer (Gustard R26) via LAN.
I have never once heard my DAC make sounds like this in over a year of use with other streaming software.
You shouldn’t need to set the buffer so large try 8000 mb perhaps, Audirvāna does seem to have sometimes a problem keeping control of UPNP devices. In my personal experience using a couple of different devices it’s long tracks and high res files that can most often be problematic. Redbook seems like it works more reliably.
Best luck with it.
Oh and maybe this is related, maybe not, I noticed it shows that it’s seemingly doing a conversion to 64 bit?? I have PCM bitdepth limit set to 20 bits since that’s the dynamic range of my DAC but it shows 64 in the attached screenshot and I can’t figure out why.
EDIT: this is not the issue, it’s just saying the computer is processing in 64 bits which is normal
