Hi everyone,
I have installed a trial version of Audirvana Studio on MacBook Air M1 and using a new Chord Qutest as a DAC. Everything works like a charm except playback of DSD files. There are occasional but consistent bursts of screeching noise during playback, always at the same place in the same track regardless of volume output. I’ve tried different tracks and different playback applications to rule out damaged files and DAC problems. Using Pine Player for playback of the same DSD files for example rolls out music flawlessly. So the issue is down to Aurdrivana processing the files.
Can anyone help me to fix this issue?
Audirvana Studio 1.10.2 (11002)
macOS 12.0.1 with 8GB physical RAM
Connected account of : Marin Pavlic
Max allowed volume: 62.1392
Sync list: 0 folders
iTunes/Music library synchronization:
Library database path: /Users/marinpavlic/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
QUTEST QUTEST
Model UID:Qutest:245F:0815
UID:AppleUSBAudioEngine:Qutest:Qutest:413-001:2
Active Sample Rate: 352.8kHz
ID 0x38 Qutest
Manufacturer: Qutest
Model Name: Qutest
Model UID: Qutest:245F:0815
UID: AppleUSBAudioEngine:Qutest:Qutest:413-001:2
11 available sample rates up to 768000Hz
32000
Audio buffer frame size : 106 to 4096 frames
Stream ID 0x39 2 channels starting at 1
22 virtual formats:
22 physical formats
Device #0: ID 0x38 Qutest Manufacturer: Qutest Model UID: Qutest:245F:0815 UID: AppleUSBAudioEngine:Qutest:Qutest:413-001:2 Model Name: Qutest
Device #1: ID 0x2c MacBook Air Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Air Speakers
