hello there
i play via my cambridge audio cxn v2 streamer with audirvana studio.at 16 bits 44.1 bitrate i can hear
any music and my streamer automatically pauses.if i upsample to rx8 brain x2 the files will be played.what is wrong here?
To contact support send a mail to [email protected]
You mention debug info in your title, but I don’t see the debug info in your post.
If you want help you need to provide some more information. The best way to provide this is click on the ‘debug info’ in Audirvana. (see picture below). After that you can paste this info (Ctrl-V Windows, or Cmd-V Mac) in your next post here.
Audirvana Studio 2.2.2 (20202)
Windows 11 (22621) with 8GB physical RAM
Connected account of : Donald de Jong
Per track: OFF
Sync list: 2 folders
AUTO: C:\Users\donal\Downloads
AUTO: C:\Users\donal\Music
Library database path: C:\Users\donal\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a02:a443:570b:1:5542:c2ed:3380:661f on port 49984
Active method: UPnP
Preferred device: [UPnP] CXNv2 (fe) Model UID:Cambridge Audio CXNv2 UID:uuid:cf9af27f-4cac-4d80-979c-354219b6c891
Selected device:CXNv2 (fe)
Manufacturer: Cambridge Audio
Model name: CXNv2
Model UID: Cambridge Audio CXNv2
UID: uuid:cf9af27f-4cac-4d80-979c-354219b6c891
UPnP device at http://192.168.2.5:8050/cf9af27f-4cac-4d80-979c-354219b6c891/description.xml
8 available sample rates up to 5644800Hz
5644800
Volume control: Yes
DSD capability: Raw DSD (MSB)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get::audio/l16;rate=44100;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=44100;channels=2:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=1:dlna.org_pn=lpcm
http-get::audio/l16;rate=48000;channels=2:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
http-get::audio/mp4:dlna.org_pn=heaacv2_l2_320
http-get::audio/3gpp:dlna.org_pn=heaacv2_l2_320
http-get::audio/vnd.dlna.adts:dlna.org_pn=heaacv2_l2_320
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmapro
http-get::audio/x-ms-wma:dlna.org_pn=wmalsl
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
NrTracks: 2
MediaDuration: 0:04:19
CurrentURI: http://192.168.2.7:49152/audirvana/audio_40.wav
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI: http://192.168.2.7:49152/audirvana/audio_41.wav
PlayMedium: NETWORK
Current transport actions:
Stop, Pause, Seek, Next, Previous
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CXNv2 (fe) Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3763 uuid:cf9af27f-4cac-4d80-979c-354219b6c891 002096fe image/png 48 48 8 /cf9af27f-4cac-4d80-979c-354219b6c891/CA-roundal-48x48.png image/jpeg 48 48 24 /cf9af27f-4cac-4d80-979c-354219b6c891/CA-roundal-48x48.jpg image/png 120 120 8 /cf9af27f-4cac-4d80-979c-354219b6c891/CA-roundal-120x120.png image/jpeg 120 120 24 /cf9af27f-4cac-4d80-979c-354219b6c891/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /cf9af27f-4cac-4d80-979c-354219b6c891/RenderingControl/RenderingControl1.xml /cf9af27f-4cac-4d80-979c-354219b6c891/RenderingControl/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /cf9af27f-4cac-4d80-979c-354219b6c891/ConnectionManager/ConnectionManager1.xml /cf9af27f-4cac-4d80-979c-354219b6c891/ConnectionManager/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /cf9af27f-4cac-4d80-979c-354219b6c891/ContentDirectory/ContentDirectory1.xml /cf9af27f-4cac-4d80-979c-354219b6c891/ContentDirectory/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /cf9af27f-4cac-4d80-979c-354219b6c891/AVTransport/AVTransport1.xml /cf9af27f-4cac-4d80-979c-354219b6c891/AVTransport/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaRadio/RecivaRadio.xml /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaRadio/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /cf9af27f-4cac-4d80-979c-354219b6c891/UuPlaylist/Playlist.xml /cf9af27f-4cac-4d80-979c-354219b6c891/UuPlaylist/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaSimpleRemote/RecivaSimpleRemote.xml /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaSimpleRemote/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /cf9af27f-4cac-4d80-979c-354219b6c891/StreamMagic6/StreamMagic6.xml /cf9af27f-4cac-4d80-979c-354219b6c891/StreamMagic6/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /cf9af27f-4cac-4d80-979c-354219b6c891/SMSearch/SMSearch.xml /cf9af27f-4cac-4d80-979c-354219b6c891/SMSearch/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/SMSearch/event DMR-1.50 M-DMP-1.50Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CXNv2 (fe) Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3763 uuid:cf9af27f-4cac-4d80-979c-354219b6c891 002096fe image/png 48 48 8 /cf9af27f-4cac-4d80-979c-354219b6c891/CA-roundal-48x48.png image/jpeg 48 48 24 /cf9af27f-4cac-4d80-979c-354219b6c891/CA-roundal-48x48.jpg image/png 120 120 8 /cf9af27f-4cac-4d80-979c-354219b6c891/CA-roundal-120x120.png image/jpeg 120 120 24 /cf9af27f-4cac-4d80-979c-354219b6c891/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /cf9af27f-4cac-4d80-979c-354219b6c891/RenderingControl/RenderingControl1.xml /cf9af27f-4cac-4d80-979c-354219b6c891/RenderingControl/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /cf9af27f-4cac-4d80-979c-354219b6c891/ConnectionManager/ConnectionManager1.xml /cf9af27f-4cac-4d80-979c-354219b6c891/ConnectionManager/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /cf9af27f-4cac-4d80-979c-354219b6c891/ContentDirectory/ContentDirectory1.xml /cf9af27f-4cac-4d80-979c-354219b6c891/ContentDirectory/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /cf9af27f-4cac-4d80-979c-354219b6c891/AVTransport/AVTransport1.xml /cf9af27f-4cac-4d80-979c-354219b6c891/AVTransport/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaRadio/RecivaRadio.xml /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaRadio/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /cf9af27f-4cac-4d80-979c-354219b6c891/UuPlaylist/Playlist.xml /cf9af27f-4cac-4d80-979c-354219b6c891/UuPlaylist/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaSimpleRemote/RecivaSimpleRemote.xml /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaSimpleRemote/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /cf9af27f-4cac-4d80-979c-354219b6c891/StreamMagic6/StreamMagic6.xml /cf9af27f-4cac-4d80-979c-354219b6c891/StreamMagic6/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /cf9af27f-4cac-4d80-979c-354219b6c891/SMSearch/SMSearch.xml /cf9af27f-4cac-4d80-979c-354219b6c891/SMSearch/invoke /cf9af27f-4cac-4d80-979c-354219b6c891/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 1
Device #0: CXNv2 (fe)
Location: http://192.168.2.5:8050/cf9af27f-4cac-4d80-979c-354219b6c891/description.xml
Model name: CXNv2
Max. memory for audio buffers: 2360MB
Device #0: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0256&SUBSYS_104314F2&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{bbe65696-1ec1-49bf-8755-770988c61498}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Chromecast devices found : 1
ID: DnsSd#Cambridge-Audio-CXN-95a8b2b70670314e914851028bf9e499._googlecast._tcp.local#0
Model name: Cambridge Audio CXN
