Cambridge Audio CXN100
If you made the test process, please use this template for your topic.
UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 175,4 - 192 - 354 - 384 - 768
DSD supported sample rate : 64 - 128 - 256 - 512
DSD Over PCM setting : None
MQA capability : Decoder
Volume:
Volume can be changed : Yes
Device can mute - unmute: Yes
Playback:
Setting do not send RAW PCM activated : Yes
Playback Control:
Gapless playbak option enabled : No
USB:
Detection:
(Windows only) best option to play to the device : Kernel Streaming
DSD Over PCM setting : DoP 1.0
