Cambridge Audio EXN100
UPNP:
Detection:
PCM supported sample rate : 44.1 - 48 - 88,2 - 96 - 175,4 - 192 - 354 - 384 - 768
DSD supported sample rate : 64 - 128 - 256 - 512
DSD Over PCM setting : None
MQA capability : Decoder
Volume:
Volume can be changed : Yes
Device can mute - unmute: Yes
Playback:
Setting do not send RAW PCM activated : Yes
Playback Control:
Gapless playbak option enabled : No
USB:
Detection:
(Windows only) best option to play to the device : Kernel Streaming
DSD Over PCM setting :DoP 1.0
Audirvana crashes when I listen to streaming music (Tidal), this doesn’t happen when I listen to music stored on my iMac. Please tell me how to fix it.
Are you using the latest Cambridge Audio firmware when you have this issue?
it happens even when i listen on the iMac speakers. so i think it is not related to Cambridge
Can you please send us the latest crash report you got from Audirvāna at [email protected]?
I have sent the picture, hope to hear from you soon. Thanks!
I want to borrow this thread,
I face the following issue with Audirvana and Cambridge Audio EXN100 with usb connection.
Connection: USB
Mode: Kernel Streaming
Advance Options: Mostly following the recommendation given here.
Issue: I hear a loud clip/pops between tracks.
What I have tried: (but doesn’t help)
Turn on/off volume controls as suggested by other posts.
Turn on/off mute when sample rate change.
It sounds like audirvana is glitching and read silence as a loud clicks, it does feel that way.
Hi, have you tried changing the Kernel Streaming optimization setting from Extreme to Standard?
Yes, Extreme and Standard doesn’t make difference on my hardware.
Im using Intel NUC11i5TNH with 16gb ram.
Nothing else running beside Audirvana, CPU and Memory usage is healthy.
I suppose you don’t have this over WASAPI, am I wrong?
I have not try enough wasapi, let me try it tomorrow and report back.
Yes after extensive hours of listening in WASAPI mode, there’s no clicks and pops between track.
So the issue is exclusive to Kernel Streaming only.
I see, it’s not an easy thing to tackle, but we will try our best.
