I am stuck on a “Loading first track” message when trying to connect to my new Cambridge CXNv2 streamer from my MacBook Pro. Audirvana will stream via uPnP successfully directly to my amp (Denon AVR x6700), and it can see the CXN in the Network menu, but it just won’t load any songs to play. Please could someone help?? Thanks- I have just registered on here so if I should direct my question somewhere else please do advise!
Thanks,
Ian
Here is the Debug info:
macOS 11.2.3 with 16384MB RAM
Registered to Ian Butt
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
AUTO: /Users/butties01/Desktop/The Dad’s stuff/Hi-Res Audio
Library database path: /Users/butties01/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: CXNv2 Model UID:Cambridge Audio CXNv2 UID:uuid:1f4b3c26-957c-4266-ab2c-24cf0f61e4ba
UPnP device at http://192.168.1.212:8050/1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/description.xml
ID 0x0 CXNv2 Manufacturer:Cambridge Audio
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
12 virtual formats:
0 physical formats
CurrentTransportState: TRANSITIONING
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CXNv2 Cambridge Audio http://www.cambridgeaudio.com/ CXNv2 3763 uuid:1f4b3c26-957c-4266-ab2c-24cf0f61e4ba 0020705e image/png 48 48 8 /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/CA-roundal-48x48.png image/jpeg 48 48 24 /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/CA-roundal-48x48.jpg image/png 120 120 8 /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/CA-roundal-120x120.png image/jpeg 120 120 24 /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RenderingControl/RenderingControl1.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RenderingControl/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/ConnectionManager/ConnectionManager1.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/ConnectionManager/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/ContentDirectory/ContentDirectory1.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/ContentDirectory/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/AVTransport/AVTransport1.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/AVTransport/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RecivaRadio/RecivaRadio.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RecivaRadio/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/UuPlaylist/Playlist.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/UuPlaylist/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RecivaSimpleRemote/RecivaSimpleRemote.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RecivaSimpleRemote/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/StreamMagic6/StreamMagic6.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/StreamMagic6/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/SMSearch/SMSearch.xml /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/SMSearch/invoke /1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 2
Device #0: ID 0x0 CXNv2 UID: uuid:1f4b3c26-957c-4266-ab2c-24cf0f61e4ba Location: http://192.168.1.212:8050/1f4b3c26-957c-4266-ab2c-24cf0f61e4ba/description.xml
Device #1: ID 0x0 Denon AVC-X6700H UID: uuid:b8d9b1c5-aa8e-1d07-0080-0005cd7fcb5a Location: http://192.168.1.176:60006/upnp/desc/aios_device/aios_device.xml
Local devices found : 4
Device #0: ID 0x5c MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #1: ID 0x2e MMAudio Device Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID UID: MMAudioDevice
Device #2: ID 0x33 MMAudio Device (UI Sounds) Manufacturer: MMAudio Device contributors Model UID: MMAudioDeviceModelUID_UISounds UID: MMAudioDevice_UISounds
Device #3: ID 0x36 ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001
Try to reduce the pre-load cache to 4000MB.
Does your CXNv2 is up to date?
Hi, thanks for the reply. Bizarrely it has worked fine today! Fingers crossed I’m ok now!
I got this working on 3.5 but with some problems upsampling to DSD but with Studio it only worked if I upsampled by 2x or used a high res file. Today it has reverted to the 'loading first track scenario) and won’t work on 3.5 or studio no matter what I do. But does work fine into an OPPO. Nothing has been changed my end as far as I know.
