Hi,
I cannot play anything with using Steinberg UR12 in Mac OS Catalina. I press play, and the time code stays at 00:00
I can play with other cards.
I’ve tested changing all preferences in the application (MQA…)
The debug is attached,
thanks !!
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.2 with 16384MB RAM
Registrado a …
SW volume control: ON
Sync list: 6 folders
AUTO: /Volumes/
CoreAudio audio path, buffer I/O frame size: 4096
Max. memory for audio buffers: 1024MB
Steinberg UR12
Model UID:YamahaUSBAudioDevice2:Yamaha Steinberg USB
UID:YamahaUSBAudioEngine2:0499:170a:0101:Steinberg UR12 :L-14344210
Hog Mode is on
Limit bitdepth to 24bit: ON
ID 0x58 Steinberg UR12 Manufacturer:Yamaha
Model UID:YamahaUSBAudioDevice2:Yamaha Steinberg USB UID:YamahaUSBAudioEngine2:0499:170a:0101:Steinberg UR12 :L-14344210
Stream ID 0x59 2 channels starting at 1
6 virtual formats:
6 physical formats
Local devices found : 3
Device #0: ID 0x5b Auriculares externos Manufacturer: Apple Inc. Model UID: Codec Output UID: BuiltInHeadphoneOutputDevice
Device #1: ID 0x4c MacBook Pro (altavoces) Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #2: ID 0x58 Steinberg UR12 Manufacturer: Yamaha Model UID: YamahaUSBAudioDevice2:Yamaha Steinberg USB UID: YamahaUSBAudioEngine2:0499:170a:0101:Steinberg UR12 :L-14344210
