Audirvana 3.5.46
SoX to DSD128 with filter type B 7th order
Bandwidth at 0dB = 90.1403
Phase = 100
Sync list: 0 folders
Library database path: C:\Users\dbank\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 5272MB
Local Audio Engine:WASAPI
Speakers (Realtek(R) Audio)
Model UID:Speakers (Realtek(R) Audio)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{6b800597-a40c-4907-b2bb-6469a0bb0476}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Active Sample Rate: 48kHz
Speakers (Realtek(R) Audio) Manufacturer:
Model UID:Speakers (Realtek(R) Audio) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{6b800597-a40c-4907-b2bb-6469a0bb0476}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Simple stereo device: No
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 44.1kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 48kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 88.2kHz
2 ch Integer PCM 20bit little endian aligned high in 32bit chunk 88.2kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 96kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 176.4kHz
2 ch Integer PCM 20bit little endian aligned high in 32bit chunk 176.4kHz
2 ch Integer PCM 20bit little endian aligned high in 24bit chunk 192kHz
Device #0: Speakers (Realtek(R) Audio) Manufacturer: Model UID: Speakers (Realtek(R) Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{6b800597-a40c-4907-b2bb-6469a0bb0476}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
