Hi Damien,
Yes, I can see sMS-200 USB as a Preferred device information UPnP device connected on the Debug page but I can’t see it listed as a preferred device in Preferences.
I only gives me the Built in Output.
Geoff
Audirvana Plus rev. 3.2.5 (3136) debug information:
running on Mac OS X 10.13.3 with 8192MB RAM
User preferences:
Remote control: IR: off, Media Keys: on (with volume control: off)
Playlists
Use UTF-8 for all: on
Start playback at launch with audio file: on
Volume knob control in rotation axis
Sample rate converter
iZotope SRC with no forced upsampling
Polarity inversion: global=off, per track=on
Volume control
DAC only
Max volume limit = 99.8%
AudioUnits not in use
SysOptimizer is disabled
iTunes settings:
iTunes integrated Mode: off
Completely deactivate iTunes playback: on
iTunes volume control: active
iTunes play position control: active
iTunes safe factor: 1
Library settings:
Sync list : 3 folders
Manual (2017-11-21 09:58:51 +0000): /Volumes/Samsung SSD Music/Samsung/My HDTracks Music
Manual (2017-11-21 09:59:06 +0000): /Volumes/Samsung SSD Music/Samsung/iTunes Music
Manual (2018-01-21 11:22:42 +0000): /Users/geoffhee/Music/iTunes/Music
Database path: /Users/geoffhee/Library/Application Support/Audirvana
iTunes Synchronization: inactive
Audio settings:
Hog Mode: on
Direct Mode: off
Integer Mode: on Mode 1
Max Mem for audio buffers: 4096MB
Max Sample rate limit: None
Sample rate switching latency: None
Preferred device: UPnP: sMS-200-USB Model UID:JF Light Industries sMS-200-USB UID:uuid:49fa9abc-6b70-7daf-7390-02c20602a2fb
ID 0x30 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:40 UID:AppleHDAEngineOutput:1B,0,1,1:0
Physical (analog) volume control: No
Virtual (digital) volume control: Yes
Stream ID 0x31 2 channels starting at 1
4 virtual formats:
2 ch Mixable linear PCM Interleaved 32 little endian Float 96kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 88.2kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 48kHz
2 ch Mixable linear PCM Interleaved 32 little endian Float 44.1kHz
16 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:40 UID: AppleHDAEngineOutput:1B,0,1,1:0
UPnP devices found : 1
Device #0: ID 0x0 sMS-200-USB UID: uuid:528C8E6C-D4A3-C659-8999-A0E9DF15AD32 Location: http://10.0.0.98:9000/plugins/UPnP/MediaRenderer.xml?player=00%3A00%3A00%3A00%3A00%3A00
