I am running an installation of BalenaSound on a Rapsberry Pi 3B+. Audirvana shows it as a network device in the sound output menu, but when clicked, it selects for a fraction of a second then reselects my default audio out. My debut info is here:
macOS 11.0.1 with 8192MB RAM
Registered to TNT team
Phase = 0
Replay Gain: by album
AUTO: /Volumes/lipu musi/Media.localized
Library database path: /Users/samcorbishley/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1758MB
balenaSound UPnP d0a7
Model UID:Ivo Clarysse, Henner Zeller balenaSound UPnP d0a7
UID:uuid:d0a713123d16a67a3f26ab2e8e934dc4
ID 0x5c MacBook Pro Speakers Manufacturer:Apple Inc.
Model UID:Speaker UID:BuiltInSpeakerDevice
Stream ID 0x5d 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x5c MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Device #1: ID 0x37 eqMac Manufacturer: Bitgapp Model UID: EQMDeviceModelUID UID: EQMDevice
UPnP devices found : 1
Device #0: ID 0x0 balenaSound UPnP d0a7 UID: uuid:d0a713123d16a67a3f26ab2e8e934dc4 Location: http://192.168.1.162:49494/description.xml
