How do I initiate the System Optimizer? I can’t get it to work on an M1 Mac Mini and a 2019 Macbook Pro. Both of these are running the latest version of Monterey. My Audirvana Studio is also updated. I get an error message and can’t optimize. Is there some way of curing this problem without going to Terminal or adding files to the Library? I tried this suggestion from RunHome Slow:
Close A+:
Trash All the files in that folder from A+ (that folder install SysOptimizer)
Trash All the files in that folder from A+ (SystemOptimizer and prefs files)
Restart Mac, restart A+. It will ask to install sys opt again.
This did not work for me. Why do I have to do some elaborate computer operation to theoretically solve this problem? It has apparently been happening before the post by RunHomeSlow which is in 2019 Thank you for your assistance!
