After the last update I don’t know what happened but I’m only getting 44khz on the output for Kernel… With Wasapi everything is fine.
Can you send us a copy of the “Debug Info” when you have selected WASAPI? You can get it in Audirvana Settings>My account
Audirvana Studio 2.2.0 (20200)
Windows 10 (19045) with 8GB physical RAM
Connected account of : Led Ferreira
Effects plugins NOT ACTIVEUPSAMPLING:
r8brain with Power Of Two upsampling
Phase linearAUDIO VOLUME:
SW volume control: OFFLIBRARY SETTINGS:
AUTO: C:\Users\ledle\Music
Library database path: C:\Users\ledle\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqliteRemote Control server:
Listening on 2804:14d:bac0:a0c1:7643:8784:83fc:a0e8 on port 55490ACTIVE STREAMING SERVICES
Qobuz: Connected as Qobuz Studio=================== AUDIO DEVICE ========================
Max. memory for audio buffers: 1350MB
Local Audio Engine: WASAPI
Use max I/O buffer size: ONPreferred device:
Alto-falantes (Realtek High Definition Audio)
Model UID:HDAUDIO\FUNC_01&VEN_10EC&DEV_0282&SUBSYS_10250775&REV_1000
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{28338fe5-48ef-4281-aaca-f06357643d3c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}Active Sample Rate: 48kHz
Mute during sample rate change: OFFSelected device:Alto-falantes (Realtek High Definition Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0282&SUBSYS_10250775&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{28338fe5-48ef-4281-aaca-f06357643d3c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}4 available sample rates up to 192000Hz
192000Volume Control
Virtual: NoMQA capability
DSD capability: UnhandledDevice audio channels
Channel 1 mapped to 1Audio channels in use
Simple stereo device: No1 output streams:
2 ch Integer PCM 24bit little endian aligned high in 32bit chunk 192kHzLocal devices found : 3
Device #0: Speaker (Digital Video Recorder)
Manufacturer: Jaksta Technologies
Model UID: jaksta_va
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{19f66421-323a-4fc3-bc0d-3aa6a2b16c05}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
Device #1: LG TV (Áudio Intel(R) para telas)
Manufacturer: Intel(R) Corporation
Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_2807&SUBSYS_80860101&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{6fff1062-c38b-4d51-8a35-73e5344495c3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Alto-falantes (Realtek High Definition Audio)
Model name: Audio Device on High Definition Audio BusUPnP
Hi @ledones,
We made an update of Audirvāna Studio yesterday, can you please try to reproduce your issue?
Yes, everything working fine today. Thanks
