time remaing is invalid. (version 1.8.1)
Hello @tlaloc,
Please remove the line corresponding to your logged-in account to avoid displaying your email address and first name/last name publicly.
Audirvana Studio 1.8.1 (10801)
macOS 12.0 with 16GB physical RAM
Max allowed volume: 76.6395
SW volume control: ON
iTunes/Music library synchronization: last synchronized on Tue Nov 16 14:42:44 2021
Listening on 127.0.0.1 on port 56713
Preferred device: CH_Precision_Renderer-162 Model UID:CH Precision CH_Precision_Renderer-162 UID:uuid:a4580f3006dc-CH_Precision_Renderer
Currently playing to UPnP device at 24 bits 352.8kHz
UPnP device at http://192.168.0.162:49152/amr.xml
ID 0x0 CH_Precision_Renderer-162
Manufacturer: CH Precision
Model Name:
Model UID: CH Precision CH_Precision_Renderer-162
UID: uuid:a4580f3006dc-CH_Precision_Renderer
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/x-aiff:
http-get::audio/aiff:
http-get::audio/aac:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/dsd
http-get::audio/dsf
http-get:*:audio/dff
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
18 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:06:00.000
CurrentURI: http://192.168.0.248:49153/audirvana/audio_8.wav
CurrentURIMetadata:
dc:titleArnesen: MAGNIFICAT 2. Ecce enim</dc:title>
dc:creatorNidarosdomens jentekor & TrondheimSolistene</dc:creator>
upnp:artistNidarosdomens jentekor & TrondheimSolistene</upnp:artist>
upnp:genreClassical</upnp:genre>
upnp:albumArtURIhttp://192.168.0.248:49153/audirvana/artwork_1_8.jpg</upnp:albumArtURI>
upnp:albumMAGNIFICAT</upnp:album>
nextURI: http://192.168.0.248:49153/audirvana/audio_9.wav
Arnesen: MAGNIFICAT 3. Quia fecit
Classical
http://192.168.0.248:49153/audirvana/artwork_0_9.jpg
MAGNIFICAT
3
object.item.audioItem.musicTrack
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Stop InstanceID in A_ARG_TYPE_InstanceID Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition CurrentPlayMode string NORMAL REPEAT_ALL INTRO NORMAL RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED vendor-defined LastChange string RelativeTimePosition string CurrentTrackURI string CurrentTrackDuration string CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED vendor-defined CurrentMediaDuration string AbsoluteCounterPosition i4 RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 AVTransportURI string TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT CurrentTrackMetaData string NextAVTransportURI string PossibleRecordQualityModes string CurrentTrack ui4 0 4294967295 1 AbsoluteTimePosition string NextAVTransportURIMetaData string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED vendor-defined CurrentTransportActions string RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED PossiblePlaybackStorageMedia string AVTransportURIMetaData string NumberOfTracks ui4 0 4294967295 A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME ABS_COUNT REL_COUNT TRACK_NR CHANNEL_FREQ TAPE-INDEX FRAME A_ARG_TYPE_SeekTarget string PossibleRecordStorageMedia string TransportStatus string OK ERROR_OCCURRED vendor-defined TransportPlaySpeed string 1 vendor-definedCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 CH_Precision_Renderer-162 CH Precision http://www.ch-precision.com/ UPnP renderer CH renderer 1.0 http://ch-precision.com a4580f3006dc uuid:a4580f3006dc-CH_Precision_Renderer 00100000 image/png 120 120 24 images/logo_120.png image/png 48 48 24 images/logo_48.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl1 rcscpd.xml /upnp/control/RenderingControl /upnp/event/RenderingControl urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport1 avtscpd.xml /upnp/control/AVTransport /upnp/event/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager1 cmscpd.xml /upnp/control/ConnectionManager /upnp/event/ConnectionManager index.html http://192.168.0.162:49152/UPnP devices found : 1
Device #0: ID 0x0 CH_Precision_Renderer-162 UID: uuid:a4580f3006dc-CH_Precision_Renderer Location: http://192.168.0.162:49152/amr.xml
Max. memory for audio buffers: 7774MB
Exclusive access: Disabled
Device #0: ID 0x3b LG ULTRAWIDE Manufacturer: GSM Model UID: 1E6DFC76-0000-0000-0A1A-0104B5572578 UID: 1E6DFC76-0000-0000-0A1A-0104B5572578 Model Name: GSM LG ULTRAWIDE
Device #1: ID 0x35 Mac mini speaker Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini speaker
Do you have this issue with files only at this frequency?
DSD256 same issue
When you have this number displayed in Studio, how it is displayed on your device screen?
There is no change in the screen.
When I tested it with other equipment, It worked normally.
Maybe It seems to occur only in CH C1HD.
CH worked normally in 1.8.0.
Yes… I still have the issue…
Do you have this issue with a 16/44 file for example?
Yes. It appears randomly with any format.
Sometimes, Last track has been played endlessly. (dsd256)
when loading the last track
when playing endlessly after loading the track again
If you try to click on next button, does it goes to the next track?
Did you had a firmware update for your device between the 1.8.0 and 1.8.5.
I can send you the 1.8.0 and 1.8.1 if you want to try reproducing the issue with those versions.
version : audirvana 1.9.0
device : CH C1 HD
source : https://www.hdtracks.com/#/album/616d770bfc639e02f2d5073f
