The player does not read files larger than 2GB in Wavpack format. Can you fix it?
Wavpack format is not supported in Audirvana. There is an issue with the 2GB file limit on Windows that has been there for a while. It should be fixed in
How do you know that wavpack is not supported?
There was a thread about.
