Hi my current output is for WASPI and when i click on ASIO that output disappears, is there a way i can change it?
Have you installed the driver for the audio device?
Yes it’s a Meridian Ultra DAC
Make sure you hit the stop button before trying to change to ASIO. If this still doesn’t work, you can try to re-install the drivers.
Yes I do stop playing before changing as I also have an IFI zen headphone DAC that runs on ASIO and is a rendered not a converter, I’ll look on the Meridian site for drivers
Hi I found a Meridan USB program that if you download and run does the job - my Meridian dealer said I didn’t need that program it was an old one. It is worth knowing it works
